SL/R231: '13 SL550 Check Valve Install - Tensioner bolts and Stepped vs Non-Stepped Valves
Old Mar 19, 2026 | 01:11 PM
ljuliano's Avatar
‘85 380SL, ‘03 SL500, ‘13 SL550
I've found mixed answers on this: are the timing chain tensioner bolts re-usable? None of the TSBs call for one time use, but one document says so. They are magnetic so I assume steel and reusable.
Also, I have both 2780504000 and 2780503300, I can't fit a 5/16 drill bit into the bore and there is no sign of a step in my cylinder head. I'm over analyzing it but that's pretty much certain that I use the non-stepped 2780504000?
Old Mar 22, 2026 | 09:29 AM
jmattioni's Avatar
2014 SL65 AMG, 2018 S560
Do you have a copy of this NHTS bulletin?
MC-10167488-9999.pdf
There may also be an MB bulletin with more details about the repair.
However, the bulletin notes that the issue is not considered damaging to the engine.
