SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: vent/manifold stuck on heat
Old May 24, 2009 | 08:45 PM
xann23's Avatar
mercedes 1980 450sl
this 1980 450sl won't open the vents to blow cold air. i know the ac is working. it's just that when i switched to defrost/heat, the vents or manifolds are stuck in that position. does anyone have a clue on how to get these working?
thanks
Old Jun 5, 2009 | 06:20 AM
ohollenbeck's Avatar
04 E500, 00 SL500, 99 SL500, 94 E420, 92 500E, 92 500E, 92 300CE, 06 Lexus GX470
Sounds like the typical CC Servo Unit failure. This is a well documented design flaw that is prone to periodic and repeated failures. There are fixes, start with this link...
(actually, go through this site in detail, lots of 107 info)
http://northernresource.com/mercedes/107-heat-ac.htm
