SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: 560sl rear under rattle
Old Mar 26, 2011 | 09:43 AM
metalmen's Avatar
560sl
i have a 1986 560sl with 200000 miles, the is a bad rattle over small bumps, i have checked bushings e brake cable,axles,fuel pump,shocks, i think the brake caliper mount is moving alot could this be it or something else? and how can i fix this thanks
Old Mar 26, 2011 | 06:27 PM
abiby's Avatar
82 380SL 96 SL500
Did you check the rear stabilizer bar links? Prone to failure.
Old Mar 28, 2011 | 03:52 PM
slik560's Avatar
SOLD both: 1987 560SL 2003 ML320
Wow. I hope it's not the caliper moving about - you need all four of those to stop. A wild guess might be part of the exhaust system, unless it's been completely replaced with new hangers as well. My 560SL has 103K and I'm getting a few noises - but more minor thumps than a rattle.
+1 for checking the stabilizer bar and maybe....shock mounts???
Good luck.
Old Feb 7, 2021 | 08:16 PM
CopterDude's Avatar
Veteran: Army
16 E400/W212, 11 C300 Sport, 07 ML350, 04 BMW X5, 03 ML350, 86 560SL, Fav? S-76B !
Good luck.
I had the same issue on my 86 560sl - Right shock was smoked/leaking and the mount bushings were compressed and hard. New shocks and bushings = rattle gone (and it was a really bad rattle).
