SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: 82 380SL DOME LIGHT BLOWN TRIGGERED BUZZER NO RADIO
Old 02-18-2018, 10:44 PM
FBolanos's Avatar
87 560SL
Hi
I tried to replace a dome light bulb on my 82 380SL and mistakenly did not realize the switch on the dashboard was on and did a short that mush have blown some fuse. The car fires up normally but the radio, dome light and hazard blinker does not come on. The traffic lights turn on but when they are on the buzzer comes on continuously non stop. All other lights and functions seem normal. I know it is my fault but I am asking please for if anyone has experienced any issue like this and knows if there is a solution or fuse graphic or diagram or may be something more I should look at to fix the problem. Thank you in advance
Old 02-27-2018, 01:32 PM
Arizona Mike's Avatar
1988 560SL, 2017 SL 450, and a few Corvettes
Originally Posted by FBolanos
Hi
I'm new to Mercedes, but I think you've mentioned the solution to your problem. Check the fuses, if you haven't already done so. Good luck.
Quick Reply: SL/R107: 82 380SL DOME LIGHT BLOWN TRIGGERED BUZZER NO RADIO
