SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: 88 560SL updates
Old 11-13-2018, 12:01 PM
tmaguire's Avatar
2005 CL55 AMG, 2004 S430 4matic, 1988 560SL, PRIOR: 2000 E430 4matic, 1994 E320 Coupe, 1999 C43 AMG
88 560SL updates
My lovely 560SL needs to have the heads rebuilt. I'm tired of the rear passenger side drip. This is a pretty typical problem but I've decided to have the work done over the winter. Doing the heads with new springs, valves and guides, plus new timing chains and guides is generally a $6,000 or so job. While they're in there, I've decided to get a few other things updated.
  1. new 822 (24/25) cams from Mike Clare
  2. new stainless tri-ys and downpipes from Elbe Engineering
  3. replace the rear end (2.47) with a 2.82 AMG W126 210mm rear end
  4. replace the open diff in that rear end with a Quaife QDF5V LSD from Kevin Bird Garage LTD
I know that one of the stumbling blocks with the M117 is air flow so I'm toying with the idea of opening up the plenum to alleviate the restriction. We'll see once they get in there. Should be fun!
I just received the LSD this morning (images attached)
Tom
Quick Reply: SL/R107: 88 560SL updates
