SL/SLC-Class (R107) 1971-1989 : 250SL, 280SL, 450 SL, 380 SLC, 450 SL, 380 SL, 560 SL
SL/R107: New timing chain increase power?
Old Aug 23, 2020 | 09:07 PM
Tom86951's Avatar
'79 450SL
I have a 134k '79 450SL with the original timing chain. I'm going to change the chain and guides either way to be safe, but am curious if anyone has noticed an increase in power after changing out an old stretched chain? I got this car from my father in fairly poor shape and am doing a rolling restoration. It's down on power pretty noticeably, so curious if the old chain might be contributing to that?
Old Aug 24, 2020 | 06:06 AM
AlterSchinken's Avatar
1985 380SL
When you get the cam covers off you will be able to see how much the chain has stretched by checking the cam timing marks against the crank. Generally speaking, late cam timing improves the higher rpm range, advanced improves the low end. If it is stretched a lot it could affect the off idle response.
Old Sep 30, 2020 | 09:33 AM
turbo 50's Avatar
500SL 450 SL 230 SL E320
I changed it and absolutely no increase in power
