SL55/63/65/R230 AMG: ABC Suspension?
Anyways I took it in, and about 600 dollars later they said it was fixed. When I got it back I had a really bad squeeking noise that didnt start till I got home.
Now this morning when I go out to my car.. I find this... Oh and the ABC warning light was on again.
At least it looks pretty bomb lowered.
NHTSA Action Number: N/A NHTSA Recall Campaign Number:
PE07042 N/A
Make: MERCEDES BENZ Model: SL CLASS
Manufacturer : MERCEDES-BENZ USA, LLC.
Year : 2003
Component :
SUSPENSION:REAR:SPRINGS:AIR SUSPENSION SYSTEM:SPRINGS/BAGS
SUSPENSION:REAR:SPRINGS:AIR SUSPENSION SYSTEM:LINES AND FITTINGS
SUSPENSION:FRONT:SPRINGS:AIR SUSPENSION:SPRINGS/BAGS
SUSPENSION:FRONT:SPRINGS:AIR SUSPENSION:LINES AND FITTINGS
SUSPENSION:FRONT:SPRINGS:AIR SUSPENSION SYSTEM
Date Investigation Opened : August 14, 2007
Date Investigation Closed : November 20, 2007
Summary:
THE SUBJECT S-CLASS VEHICLES CONTAIN A COMPRESSED AIR SUSPENSION SYSTEM THAT USES AIR STRUTS ON EACH OF THE FOUR WHEELS IN LIEU OF TRADITIONAL SPRINGS AND SHOCK ABSORBERS. THESE AIR STRUTS USE COMPRESSED AIR TO SUPPORT THE WEIGHT OF THE VEHICLE AND CONTROL RIDE HEIGHT. IN THE EVENT OF THE LOSS OF AIR FROM THE SYSTEM, AN ALERT WILL FLASH ON THE INSTRUMENT CLUSTER WARNING THE DRIVER TO EITHER DRIVE CAREFULLY OR TO STOP THE VEHICLE. THE VEHICLE RIDE HEIGHT CAN BE REDUCED BY AS MUCH AS 105 MM BELOW NORMAL RIDE HEIGHT BEFORE THE FULL LOAD OF THE VEHICLE FOR THAT WHEEL COMES TO REST ON A STEEL ROD, WITH A RUBBER STOP ON THE END, LOCATED IN THE SHOCK ABSORBER. THIS REST-STOP CONDITION IS DESIGNED SUCH THAT THERE IS NO IMPACT ON VEHICLE CONTROL. MERCEDES-BENZ (MBUSA) SUPPLIED VIDEO SHOWING A VEHICLE IN THIS CONDITION OPERATING UNDER SEVERAL DIFFERENT SITUATIONS INCLUDING EVASIVE MANEUVERS DEMONSTRATING THE ABILITY OF THE VEHICLE TO BE CONTROLLED EFFECTIVELY WITH A RIDE HEIGHT REDUCED TO THE MINIMUM. ONLY THOSE COMPLAINTS TO ODI AND MBUSA THAT ALLEGED A STEERING INTERFERENCE DURING A REDUCED RIDE HEIGHT CONDITION WERE COUNTED IN THIS RESUME FAILURE REPORT. SOME COMPLAINTS ALLEGED THAT WITH A REDUCED RIDE HEIGHT AND A "STOP NOW" WARNING MESSAGE THERE WAS A RUBBING NOISE WHEN TURNING, BUT THE ABILITY TO STEER THE VEHICLE WAS NOT COMPROMISED. A SAMPLING OF WARRANTY CLAIMS SUBMITTED BY MBUSA DID NOT REVEAL ANY INDICATING A LOSS OF CONTROL DUE TO AN AIRMATIC SYSTEM FAILURE. THERE WAS ONE CRASH REPORTED BY MBUSA TO ODI BUT THE INFORMATION AVAILABLE INDICATED THAT IT RELATED TO SUSPENSION SYSTEMS AND IT WAS NOT POSSIBLE TO VERIFY THAT THE INCIDENT WAS RELATED TO AN AIRMATIC SYSTEM FAILURE. FURTHER USE OF AGENCY RESOURCES IN THIS MATTER DOES NOT APPEAR TO BE WARRANTED. THE AGENCY WILL CONTINUE TO MONITOR COMPLAINTS AND OTHER INFORMATION RELATING TO THE ALLEGED DEFECT IN THE SUBJECT VEHICLES AND WILL TAKE FURTHER ACTION IN THE FUTURE IF WARRANTED. THIS PRELIMINARY EVALUATION IS CLOSED.
i REALLY hope you still have warranty but it doesn't sound like you do. ABC is one of the most expensive things to fix on the SL.
You're in for $6k~+ while they investigate to try and find the problem.
My '04 was in the shop 6 times for the ABC thing, each time being told it was fixed and each time them finding something else to try and fix it.
There is a Mercedes technical service bulletin for this problem. It's order number P-B-32.50/34b. If it was me, I'd go back to the dealer and ask them to run that procedure as a warranty repair.
Good luck!
Good luck!
"Since this is a maintenance procedure, it is not covered under warranty." They said they had to "bleed" to the ABC system because it was clogged or whatnot, and then they made the car do a "rodeo" thing where it lifted itself up and down and left to right. In any case, they said it was maintenance because the system was clogged.
I f'in hate the Stealerships.
maybe its because when the strut is lowerd its more tight and less air comes in and out ???
obviously its gonna make a noiser ride and less comfortable ...... but even lowerd SLz are pretty darn smooth . U can tell the difference even with the sound when going through bumps with a lowerd one then to a stock height .
the stock height makes more of a swoosh sound , almost like a wave ,very loose compared to a lowerd SL .
I f'in hate the Stealerships.My second guess is Laguna Niguel.
I f'in hate the Stealerships."Since this is a maintenance procedure, it is not covered under warranty." They said they had to "bleed" to the ABC system because it was clogged or whatnot, and then they made the car do a "rodeo" thing where it lifted itself up and down and left to right. In any case, they said it was maintenance because the system was clogged.
I f'in hate the Stealerships.Here's the text from the TSB I mentioned:
Note: The vehicle's level may lower at any of the following: an individual strut, front or rear axle, right or left vehicle side and/or complete vehicle.Note: For both conditions listed below, large temperature differences in the ABC suspension system between operating and when stationary for an extended period can also cause the vehicle to lower slightly.
The lowering is caused by temperature dependent volume changes in the ABC oil within the suspension struts. The vehicle can lower up to 10 mm when the temperature difference is 30°C (ABC operating temperature 20°C / outside ambient temperature -10°C).
Condition 1:
If a vehicle lowers after being stationary (engine off) within approximately one week, this is likely due to internal leakage in the check valve of the front (Y36/1) or rear (Y36/2) axle valve blocks. The internal leakage is the result of deposits or contamination on the valve seat of the check valve. In order remove the deposits, flush the ABC system (reference WIS document AR32.50-P-0025A).
If the complaint still continues to occur after the above procedure, the respective valve block must be replaced (reference WIS documents: Model 215/220 - AR32.50-P-0001N and AR32.50-P-0002N and Model 230 - AR32.50-P-0001R and AR32.50-P-0002R).
Caution! It is imperative that the utmost attention for cleanliness be observed when working on the ABC suspension system in order to ensure that no contamination enters the system. Small particles of debris can contaminate the hydraulic fluid, thus causing internal leakage.
Condition 2:
If a vehicle lowers only after being stationary (engine off) for more than approximately a week, this is a characteristic of the hydraulic design and is not a complaint that requires a repair. The check valves in the front and rear axle valve blocks have a metal valve seat. The inherent design of this sealing method, required for system durability, permits a limited level of leakage which can result in the vehicle slowly lowering. If the vehicle does not lower significantly until after approximately one week has passed, do not perform any repair attempts.
In any event since the problem has reoccurred, the check valves should be replaced under warranty.
good luck..
I give it to them, then give me a loaner, and take it off the the MB dealer.
I hope at least...
