SL55/63/65/R230 AMG: Ho do you remove the side grills
Old Jan 24, 2010 | 05:00 PM
d8ean's Avatar
the two finned side grills, how do they come off?
looking to detail behind them and the actual items themselves
TIA
Old Jan 24, 2010 | 05:59 PM
BeltFedBob's Avatar
From: Lynnwood in summer, Fountain Hills during the rainy season in Wa.
2008 Maserati QP EGT, 2005 SL55AMG , 2002 CLK55AMG 2002 C230K Coupe
They are afixed with 3m tape. You will be sorry if take them off unless you have the tape to put them back on.
Old Jan 25, 2010 | 01:50 AM
d8ean's Avatar
what are the two screws holding ??
surely just new tape would be suffice?
anyone else done this....
Old Jan 25, 2010 | 08:04 AM
jrgator's Avatar
ML63, ML320
Sure, I did it to paint them black. Another forum member gave a great tip. Loosen the 2 torx screws and then use floss or fishing line to slide between the grill fins and the fender so as to not scratch the paint. Pick up some 3M two sided tape from a body shop, it's dark grey, and replace the old tape when you re-install the grills.
Old Jan 25, 2010 | 10:06 AM
BeltFedBob's Avatar
A bit of work each time you want to clean them. You will also need adhesive solvent to loosen the tape and clean the body panel and fins of the old tape residue.
