SL55/63/65/R230 AMG: Evosport | New Lightweight 2-Piece Front & Rear Rotors for SL63 AMG
Designed as a direct brake rotor replacement for the OE 2-piece front (not 390mm) and 1-piece rear brake rotors. No modifications are necessary. The Evosport rotors will bolt directly to the car and work with OE AMG brake calipers. Not only will the upgraded multi-piece "floating" rotor design help mitigate brake fade, but are lighter than stock and reduce unsprung weight by 26-lbs. on all four corners! This means better acceleration, braking and cornering. In addition, you get to maintain the AMG calipers without going to a more expensive solution that requires replacing them.
Drilled and slotted to match the OE rotors, hats are lightweight aluminum and black hard anodized. And unlike the stock rotors that only vent correct on one side (or have universal venting), the Evosport rotors have a Right and Left application for proper venting of the disc and chaneling of airflow.
Note: Coming soon for SL63 AMG with 030 Performance Package 390mm Front Rotor and late model SL65 AMG and SL600.
Benefits:
- Direct bolt-on design requires no modification
- Works with OE AMG calipers
- Lightweight design (26-lbs unsprung weight savings over stock!)
- Aluminum hat, hard anodized (Black)
- Better value and cost of ownership over OE! The OE 2-piece 360mm rotor sells for $990 EACH!
- Unique Left/Right application for proper venting/airflow (unlike OE)
- Replaceable discs and hardware
- Better heat dissipation and less brake fade
- Improved acceleration, braking and cornering with less unsprung weight!
Includes Front and Rear rotors with black anodized hats (Front or Rear pairs can also be purchased separately). For more information or to order, CLICK HERE.
Please feel free to call or email us with any questions.
Anthracite anodized hats shown below. Actual rotors have black anodize:
Evosport 2-Piece Rotor Installed on SL63 IWC AMG (Note: Right-Side Rotor Shown):
Yes, the air filters are a direct install for the factor airbox. They do flow much better than stock which helps performance. We also offer several intake options for your car. Please email us at sales@evosport.com for more information.
