SL55/63/65/R230 AMG: Removing Side wooden trim, any HELP???
Old May 26, 2010 | 01:36 PM
kamilclk430's Avatar
W215 V12TT Build by Speedriven, W221 S550 4Matic
Hey guys,
Going in the garage to try and figure out how to pull the side wooden trim off the door panels. I know how to get the center console done already, just need some directions on how to get the sides out. Any help would be great.
KAMIL
Old May 26, 2010 | 06:56 PM
JUST DID MY OWN DIY and posted it up. GOOD LUCK TO ALL.
I WILL POST PICTURES OF MY FINISHED PROJECT WHEN DONE
Old May 26, 2010 | 08:51 PM
BeltFedBob's Avatar
From: Lynnwood in summer, Fountain Hills during the rainy season in Wa.
2008 Maserati QP EGT, 2005 SL55AMG , 2002 CLK55AMG 2002 C230K Coupe
Removing the door panel is really simple. Turn the "SRS" emblem 90 degrees and pull it out. Remove the screw, remove the rear door plate and the door panel just pulls off. Be carefull of the door handle cable. Pop the clips off the trim studs and the trim comes right off.
Good luck.
