MBWorld.org Forums
MBWorld.org Forums (https://mbworld.org/forums/)
-   SL55 AMG, SL63 AMG, SL65 AMG (R230) (https://mbworld.org/forums/sl55-amg-sl63-amg-sl65-amg-r230-49/)
-   -   Installation instruction for R230 SL55/SL65/SL500 carbon interior trims (https://mbworld.org/forums/sl55-amg-sl63-amg-sl65-amg-r230/364131-installation-instruction-r230-sl55-sl65-sl500-carbon-interior-trims.html)
DCTMOTORSPORTS 08-21-2010 08:03 PM
14 Attachment(s)
Since many members asked how to remove/install the wood centerconsole and door trims on R230 SL models, we decieded just make a thread post porviding the detail step-by-step installation instruction for R230 owners' reference.
If you still have any question about the installation, feel free to contact us
[email protected]
First part, the door panels
Attachment 408421
Attachment 408422
Attachment 408423
Attachment 408424
Attachment 408425
Attachment 408426
Attachment 408427
Attachment 408428
Attachment 408429
Attachment 408430
Attachment 408431
Attachment 408432
Attachment 408433
Attachment 408434
DCTMOTORSPORTS 08-21-2010 08:09 PM
The center console
10 Attachment(s)
Part 2: center console
Attachment 408435
Attachment 408436
Attachment 408437
Attachment 408438
Attachment 408439
Attachment 408440
Attachment 408441
Attachment 408442
After remove the components (AC control/shifter frame/convertible op switch) from old panel, put them on new carbon console trim and put the console back!
Completed! :)
Attachment 408443
Attachment 408444
AdrockTT 08-21-2010 11:43 PM
Helpful post, thank you.
Is removal of the shifter knob/boot the same for keyless go equipped cars?
Rick SL55 08-22-2010 08:49 PM
it easier to do it after looking at pictures.
thanks.
DCTMOTORSPORTS 08-23-2010 01:25 PM
shift knob removal
keyless go shifter removal is pretty much same as regular shifter
just make sure don't bend the connector pins
check this thread for more info!
Keyless go shifer
AdrockTT 08-23-2010 07:11 PM
Thanks for your response. I had read the keyless go shifter thread in the past and specifically wanted to avoid breaking/bending/ruining the pins.
In rereading the thread now, I think I'm still confused the best approach to prevent breakage.
Your instructions explain to be sure the pins are all the way into the holes before tightening, but don't cover how to safely remove the shifter/button without damaging the pins.
Could you (or anyone) clarify that part so I can save myself the soldering solution headache part :)
Thanks!
DCTMOTORSPORTS 08-23-2010 09:34 PM
Is not that complicated!
1 pull up the boot
2 release the nut at the bottom (clockwise, as I remember)
3 pull the whole shifter knob straight up
DONE~ :)
Thanks!
Thericker 08-23-2010 09:51 PM
1 Attachment(s)
Excellent info thnx for sharing! Q: All that has to come off to replace/take off the (2) small wood door strips??
Lastly I want this Suede/Alacantara shifter boot cover (I have Keyless-Go 2005 if matters?) How much? Availability? Thank you!
Attachment 408445
DCTMOTORSPORTS 08-24-2010 02:49 PM
1 Attachment(s)
I know it is huge effort to remove just those 2 wood trims, but if you don't do it and try to pull off the trims with force from outside, all these small rings will fall off and rattling within your door panel
Also, you can not put the new trims back without those rings
Attachment 408446
http://i237.photobucket.com/albums/f...lation/020.jpg
ANT1SL55 06-29-2012 03:58 PM
Hello, I have a couple of quick questions, this may be off the topic but I'm having problem with my shifter. Since you are the professional in this type of job. I am hoping you can help me. My shifter is stuck in "Park" how can I remove the panel on my center console? Is is possible to remove the panel w/o shifting the gear from park to neutral? Your reply is very much appreciated. Thank you and have a good day.
© 2019 MH Sub I, LLC dba Internet Brands
