SL55/63/65/R230 AMG: "churp" When Starting Out
HAS ANYONE HAD THE CHURPING SOUND I HEAR WHEN STARTING OUT. LOW TO MEDIUM THROTTLE. ITS QUICK SOUNDING, ALMOST A CLICK. I HAVE JUST OVER A THOUSAND MILES. I HAVENT DISCUSSED OR BROUGHT IT TO THE DEALER YET.
It's a chirp or almost a 'twang', and occurs sometimes at less-than-full acceleration, or even in moderate cornering if you then sort of stick the throttle just a bit. It's not terribly bothersome, but I did call it to their attention. Again they say it's in the SL55 exhaust, and is because it's free-flowing. I would very much be interested should you learn otherwise, or if there's a fix for this.
thanks!
By the way, do any SL55 owners get brake squeal after driving a bit? Basically wonderful car, but these are the only 2 oddities.
thanks...
gene
___________________
'03 SL55 black/charcoal
all options but distronic
Regards,
gene
__________________
'03 SL55 black/gray
thanks!
gene
________________
'03 SL55 black/gray
www.ingerletter.com
Nothing to do about it, same apparently as the brake squeal, which I have still after 5,500 miles.
Also, I have the slight sound from the fuel pump in the gas tank in the rear of the car. Am told it is normal even though I see that some others are having their tanks replaced.
BUT, I love this car!!!!
Best I have ever owned and I bought it to replace a 1999 Ferrari 355 F1 Spider and a 1996 Porsche 911.
Good luck with your churp!
As to the brake squeal; that's not always present; primarily on low-speed 'cruising' after being warmed up; not present at all in other conditions. Suspect it is the ceramaic disc material used to ensure high-speed superior braking.
I too should have noted that after 2 Ferraris, 2 Porches, 1 awful BMW 850 (years ago), this is my 8th Benz, and by far not only the best 'benz, but the best engineered and reliable overall car that I can recall owning, with the fewest irritations and no mechanical flaws (this one was build in Feb. '03, so I think has the gas tank change and some other minor changes since last year that I was luckly enough not to have to address). It is a fantastic car!
cheers..
gene
____________________
'03 SL55 black/gray
www.ingerletter.com
I have a 'donk' from the front nearside suspension when manoeuvring slowly on lock and also a 'grunt' from the rear offside area under heavy braking when pushing the car hard.
Still love it though
No brake squeal.
i will post when i find out what they say.
realcanuk
I had previously replied that I had a churp on my SL55 and that the dealer had put something on the supercharger clutch that seemed to be helping. He called it a "compound" of some sort.
Well, after several weeks, the churp is gone completely. If you have the problem, you may ask your dealer about the solution my dealer used (RAB Motors in San Rafael, CA).
Good luck!
