SL55/63/65/R230 AMG: Anyone cut their filters open? And get metal shavings?
Old Oct 12, 2013 | 12:35 AM
PS94's Avatar
2004 SL55 AMG Kompressor
I recently did an oil change...I cut my filter open, washed it with solvent, and evaporated the results. I had a pile of non ferrous metal. I'd say
I think my car is very, very ill. What is a common wear item? My denial is hoping its something as minor as one of the (many) timing chain guides...
Are they aluminum under the UHMW?
And I erroneously posted this post in the wrong forum earlier, and didn't get replies!
"Anyone else cut open their filters after a service?
Did mine for the first time, and got a 'not insignificant amount' of shavings...It's non ferrous, and the amount would probably cover a key on a standard computer keyboard...I'm completely unfamiliar with this motor. Where should I start looking for my time bomb? Timing chain tensioners?
Car has 96,000miles (154,000km)"
Old Oct 12, 2013 | 08:19 AM
alx's Avatar
alx
Are you burning oil?
Old Oct 12, 2013 | 08:46 AM
cal1's Avatar
SL55, ML500 & Acura TL
Check this out: https://mbworld.org/forums/5750426-post44.html
You might shoot amok55AMG a PM and ask him about what he found.
Old Oct 12, 2013 | 02:02 PM
PS94's Avatar
Car is using 1-1.5qt between oil changes...I'm unsure if it's burning it all, but it is losing some out of the valve covers, I was going to do that this winter...You can smell the distinctive hot manifold oil cook at stoplights...
Hmm, that could be it....I'll try and see what he found...I'm hoping I don't have to go deeper than the front cover removal...
Old Oct 12, 2013 | 08:38 PM
alx's Avatar
alx
I would leave it alone...
Old Oct 12, 2013 | 10:13 PM
PS94's Avatar
But what is the filings doin when they pass through the pump? Sure they're getting caught in the filter....but on their way there......:/
Old Oct 13, 2013 | 08:21 AM
alx's Avatar
alx
have you seen the innings of an oil pump? plastic shavings are not going to scare the gears inside
plastic particles are usually one of three things - tensioner guides, electrical connector grommets or valve guide bushings.
worn tensioner guides will make the timing chains chatter. you will hear them usually way before they do something stupid.
electrical connector grommets will cause oil leaks which you will see.
worn valve guide bushings will result in excessive oil consumption.
pick one in your mind and leave the motor alone
my 2 cents
Old Oct 13, 2013 | 09:49 AM
amok55amg's Avatar
SL55AMG + SL600 + E320 + A180
Chain cover chewing
alx ….. you should add chain cover chewing with large aluminum pieces in the engine as a result to do havoc ……
https://mbworld.org/forums/5643945-post3.html
Old Oct 13, 2013 | 12:04 PM
alx's Avatar
alx
He says particles are not metal. If particles are metal- this is a whole different story and one cause for serious concern.
Old Oct 13, 2013 | 05:29 PM
PS94's Avatar
I never said it was not metal, i said it was non ferrous, so not containing iron..My guess is aluminum...
Old Oct 14, 2013 | 09:39 AM
Benz-O-Rama's Avatar
Why not just do a Blackstone Labs report? I do them on all my cars, and they can tell you exactly what the object is, and take a guess at possible damage already done, and likely future damage.
