SL55/63/65/R230 AMG: Help part number pleeeeeeease !!
Old May 22, 2014 | 11:33 AM
sound 8's Avatar
SL 63 W/B AMG , S600,C220
Does any one have the part number for the coolant pump for I/c for
SL65 AMG 2005. I need the MB number.
Old May 22, 2014 | 05:28 PM
Maverick1975's Avatar
Vath ML63 Brabus C63 SL63 CLK63BS C63BS
Broken already?
Old May 22, 2014 | 05:50 PM
cm60k's Avatar
OEM #: "000 500 03 86"
Bosch #: "0392 022 010"
ZAYED,,
Old May 23, 2014 | 09:40 AM
sound 8's Avatar
Thanks cm60k. Would you know how long it takes to fit on a SL65.
MB say it takes three and a half hours, 500 pounds in labour. I know it
needs bleeding, so if you have info how to fit one I would be obliged.
Old May 23, 2014 | 11:09 AM
cm60k's Avatar
I believe it needs less than that, the same fitment with all 55K Engines,
ZAYED,,
Old May 25, 2014 | 07:58 AM
ttboost's Avatar
CTS-V
Use the Bosch pump...WAY bigger, and cheaper (yes, Amazon has it). Took me about an hour and a half to do mine, including bleeding. You might have to check coolant level after a drive or two...
Old May 27, 2014 | 10:40 AM
sound 8's Avatar
How To: Change / Upgrade your Intercooler heat exchanger pump. Mercedes 55K engines - YouTube
ZAYED,,
Hi, and thanks for the Vid, would the pump be in the same place on a SL65
2004 230.
