SL55/63/65/R230 AMG: Right seat inop
Old Sep 30, 2014 | 03:49 PM
fxrs1955's Avatar
2014 SL550
Right seat inop
My right seat wont move forward and I need to remove it to find the problem. Any ideas about how to move it forward manually?
Or remove the seat cushion so I can access the motors?
Old Oct 9, 2014 | 10:18 AM
coldwell's Avatar
2006 sl55 030 option - sold
do all other functions work .
Old Oct 9, 2014 | 11:02 AM
fxrs1955's Avatar
2014 SL550
Everything else works, I'm thinking its the motor or the control module. I spoke with the dealer and they say the same.
Old Oct 9, 2014 | 10:59 PM
coldwell's Avatar
I have never seen one go bad , but that is not saying much. Can you check the seat track for something stuck in it , like change or some other thing. Raise the seat as much as you can and give it a look.
If you can get your hand under there and feel the motor trying to move , that could tell you something also.
Old Oct 10, 2014 | 06:46 AM
fxrs1955's Avatar
2014 SL550
The motor gets a little warm but doesn't move. I'm fairly sure something jammed the track and burnt the motor. It's only 200.00 from the dealer but it's a pain to install.
Old Oct 10, 2014 | 06:55 AM
coldwell's Avatar
if you can feel the motor click or try to turn on , it is still good. you will just need to find the object that is stuck in the track.
Old Oct 10, 2014 | 09:11 AM
fxrs1955's Avatar
2014 SL550
The tracks are fine, the motor's bad. One of those things, it's warm but it's not trying to run. I'll order one and replace when my shop has the time.
