SL55/63/65/R230 AMG: Heat exchanger options for the SL55...
Old 02-11-2016, 10:01 AM
B Feelgood's Avatar
SL63, GTR
I am interested in adding an additional heat exchanger to my SL55 since I will be running a 77mm clutched pulley.
I thought it would be nice to put together a complete list of all the upgraded heat exchanger options. Also, the modifications that are necessary to get them to fit since no one offers a 100% plug/play or direct fit for the SL.
If you have one of these heat exchangers installed on your SL55, please chime in. Include your over satisfaction level and any fitment adjustments that were necessary. (relocating hoses, cutting/welding new tabs, moving oil cooler, trim inside of bumper cover, etc)
Is it best to add one of these in-line with the OEM unit or replace the THE OEM unit? If I'm not mistaken, the original unit is sandwiched in between the A/C radiator and engine radiator.
If I have missed any additional heat exchangers, let me know and I'll add it to the list.
1. Frozen Boost
2. PLM
3. Eurocharged
4. C&R Racing
5. FabTech
6. OEM Mercedes SL65
7. ZZP Performance
Old 02-11-2016, 11:31 AM
latemodel21's Avatar
2003 SL55 / 2002 SLK32
Hey Brian,
here is a very long thread that while not SL55 specific, has a lot of good info on heat exchangers (including core sizes for a multitude of available options).
https://mbworld.org/forums/m275-v12-...ion-pumps.html
My only contribution is that after looking around (a little more than a year ago) I could not find anything Ideal for the sl55 application so I installed an e55 PLM HE which IMO is as big as you can fit in the space we have (while properly remounting the oil-cooler)
https://mbworld.org/forums/sl55-amg-...ml#post6307087
I would also add that I always like adding an air-bleed port to any heat exchanger add-on
Cheers,
Chris
Old 02-11-2016, 11:44 AM
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
I used a EC ,relocated oil cooler ,
Old 02-11-2016, 11:50 AM
That looks like an easy-fitting quality solution .... nice!
maybe they will run group buy if this thread stirs up some interest ?
Chris
Old 02-11-2016, 03:15 PM
dRockSL55's Avatar
MBs: SL55, GLK350
Nice install!
Where did you relocate the oil cooler, just further back and up?
Did you fab up your own oil cooler lines from the cooler to the existing inline connections? If so do you remember the connection sizes?
I need to do the same on my sl, I replaced my oil cooler over the summer but should have thought ahead and measured the fittings on the old one before tossing it
Old 02-11-2016, 03:19 PM
JohnH's Avatar
2004 SL55 AMG
This was supplied by EC after the first one they sent didn't fit. Assume the sourced from C&R.
Old 02-11-2016, 08:59 PM
B Feelgood's Avatar
SL63, GTR
I came across this heat exchanger from ZZP Performance.
It looks like this could just be bolted onto the crash bar with the two supplied tabs that are already in place at the end of the HE? Very similar to the C&R that JohnH has pictured above? May be possible to leave the other stock coolers in their original locations?
Would love to hear some thoughts on this one.
Overall measurements of 32.5x6.5x2.25
Core measurements of 28x6.5x2.25
2 row, dual pass
Maximum cooling, minimum weight, fully tig welded and pressure tested
2 stainless bolts and nuts
Includes 2 fittings and 4 hose clamps
49" of 3/4" hose
6.4 pounds
1.8 liters of capacity
4000 sq. in. of fin area
Attached Thumbnails Heat exchanger options for the SL55...-zz_zz005_2.jpg   Heat exchanger options for the SL55...-zz_zz005_1.jpg
Old 02-12-2016, 03:51 AM
cnterline's Avatar
IIRC I lowered mine a little to center the opening in the front bumper cover for max airflow ,and in doing so I had to relocate oil cooler to max that airflow coming through the HE ,I'll have to look it's been awhile but I believe that's why I moved oil cooler,
Old 02-12-2016, 05:07 PM
carguyshu's Avatar
2003 E55, 2003 SL55, 2014 CLS63, 2018 q50 Redsport, 1968 Camaro SS, 1999 Trans am Firehawk
2 row, dual pass
49" of 3/4" hose
6.4 pounds
I bought this for my SL55, but haven't had time to try and install it yet. If (when?) I do, I'll let you know how it goes.
Old 02-13-2016, 07:36 PM
m-svt-amg's Avatar
2003 SL55
I just picked up a thermal coated afco for my lightning. Its a shame they dont have one for an sl55.
Ive been looking into the fabtech, but looking forward to finding out our best option!
Old 02-14-2016, 04:54 AM
SL65amg's Avatar
'05 SL 55 Black/Black w/mods from Eurocharged/Kleemann/BuckheadImports
Post Mine is from Eurocharged
My upgraded HE is from Eurocharged, bought it from Jerry....its in line with the stock one...the shop that installed it said its better to have both instead of just a replacement...works great...even in very high summer heat with high humidity the temp needle doesn't get high...even in bumper to bumper 5 o'clock traffic....I also have the Johnson CM30 intercooler pump with water wetter added and phenolic spacers.....
Old 02-14-2016, 05:12 AM
m-svt-amg's Avatar
2003 SL55
Did you also do split cooling? If so, your temp guage isnt telling you much about air temps, just block coolant temps...
Phenolic spacers sound great, does anyone have data demonstrating measured results?
As far as the list of available HE, i think it should also specify which are single vs dual pass, and what level of effort is expected to install in an sl55 (most info available seems related to e55, thanks for your writeup chris!)
Old 02-27-2016, 08:12 PM
m-svt-amg's Avatar
2003 SL55
Any update on sl55 specific fitment? Really interested in comparing ftp with zzp.
Do they have an option not to paint the letters on the exchanger? I would prefer not to have the officer pulling me over think im saying "f the police" on the front of my car...
Edit: does the PLM have the same specs as zzp, with specific mountings for the oil cooler?
Old 02-28-2016, 02:13 PM
dRockSL55's Avatar
MBs: SL55, GLK350
Did you run new lines to the cooler (to the inline connections I would assume) or just modify/bend the stock ones?
Old 03-10-2016, 03:36 PM
Benz Mike's Avatar
2006 SL55 AMG
Who has the best fitting HE for the money ?
Old 03-21-2016, 11:18 PM
B Feelgood's Avatar
SL63, GTR
Just purchased the ZZP Performance heat exchanger. Will try installing it probably next week.
Old 03-21-2016, 11:20 PM
m-svt-amg's Avatar
2003 SL55
Looking forward to hearing about your experience with installation. Are you planning on using it in-line with the stocker?
Old 03-21-2016, 11:30 PM
B Feelgood's Avatar
SL63, GTR
That's the plan for now. The brackets look like they "should" line up with the front support. Hoping for an easy install!
Old 03-21-2016, 11:31 PM
m-svt-amg's Avatar
2003 SL55
Which kit did you purchase from zzp?
Old 03-21-2016, 11:39 PM
B Feelgood's Avatar
SL63, GTR
I picked up this one in the link below for $215 shipped. It's been out of stock for a couple of weeks and is now showing as available.
http://zzperformance.com/ecotec/zzp-...exchanger.html
Old 03-22-2016, 04:38 PM
Benz Mike's Avatar
2006 SL55 AMG
Are the dimensions of the ZZP close to the other heat exchangers that are known to fit ?
Old 03-27-2016, 06:48 PM
m-svt-amg's Avatar
2003 SL55
Any update on fitment?
Old 03-27-2016, 07:15 PM
Benz Mike's Avatar
2006 SL55 AMG
Also wating for an update. Its the last thing I have to buy for my SL build.
Old 03-27-2016, 10:21 PM
B Feelgood's Avatar
SL63, GTR
I received the HE on Saturday but didn't get to install it this weekend due to the holiday. It will be done before the end of this week, hopefully Wednesday or Thursday.
First impression is pretty good considering the price!
Old 03-27-2016, 11:25 PM
Benz Mike's Avatar
2006 SL55 AMG
Looks good ! It will Be nice because you can mount it backwards and wont see the ZZP through the grill.
Quick Reply: SL55/63/65/R230 AMG: Heat exchanger options for the SL55...
