SL55/63/65/R230 AMG: General a/c question...
Old Jul 18, 2016 | 08:14 AM
Tomcat SL's Avatar
2004 SL55 AMG
This site is so knowledgeable I thought I'd ask...
On a different German sedan my a/c quit blowing cold.
My pressure manifolds are reading:
Overnight, system off Low 90 psi, High 90 psi (so they normalize)
Start car and compressor the low bumps to 95 psi then settles back to 90psi...High goes to 0 psi.
Any suggestions?
Old Jul 18, 2016 | 09:19 AM
Tomcat SL's Avatar
2004 SL55 AMG
Thanks.
This is what I was leaning towards.
So if I bleed off the residual 90 psi I have and add Freon...you think the compressor will not "make pressure"?
Tom
Originally Posted by Plutoe
Your compressor is shot(unable to make pressure) and assumes that you have the required amount of refrigerant in the system!! However if no refrigerant=no pressure!!
Old Jul 18, 2016 | 10:35 AM
Tomcat SL's Avatar
2004 SL55 AMG
When I depress the pin on the low side valve, I get a lot of pressure with visible gas...gaseous Freon I'm assuming.
