SL55/63/65/R230 AMG: DUDMD SL65 AMG - Build/Work Log
Old 11-16-2016, 11:11 PM
  #76
DUDMD's Avatar
2005 SL65 AMG, 04 S600
Originally Posted by AMG-Driver
Do you expect more power with less boost from the single Turbo? Maybe it is more efficient because our little twin turbos are running at the edge. But compression ratio is only 9.0 on our V12 when I remember correctly. So I assume it will need certain boost also with the single Turbo to make serious power.
The factory turbos are pretty much maxed out at 300whp each on race gas. On my low reading dyno, with ms109 and extra timing, full max boost possible it put down 602whp.
The 7675 Precision turbo is good for 1200whp as a single turbo. I think it will make 600-700whp on my dyno dynamics dyno with less than 20psi on pump gas. We can then either use race gas and add timing, or leave timing on software add more boost for my goal of 750-900whp. The main advantage is power till redline without losing boost/hp, which will turn into an even better hwy killer car.
Old 11-16-2016, 11:14 PM
  #77
DUDMD's Avatar
Originally Posted by RaceHorse
I don't think its impossible to come up with the right combo to make power with the car,(others have done it) but the weight and gearing are always working against it compared to the vette or camaro.
I hope you have some tricks up your sleeve to get the tranny to cooperate and make a clean pass at the track. It seems others have had success making power with different turbo setups on the dyno, but shifting under load from 2-3 or 3-4 seems to send everyone scratching their heads trying to tune accordingly.
Yes that will be tricky. Would be nice if I could alter the tcu I've got in there now, which has some sort of a tune since it holds M mode no problem.
I can also see if someone would maybe be able to remove the torque limiters completely, since I won't need them anymore due to not make much torque at lower rpms.
Maybe I'll have to have my boost controller drop boost to wastegate pressure for the last 500rpm to reduce power/torque.
Maybe speedriven or someone else can help out there, since they did run a 9 seconds pass on the sl600.
Old 11-17-2016, 11:32 AM
  #78
overZealous1's Avatar
sl55 amg
A little input for the rear mount turbo set ups. Even with all of the longer tubing, full boost is only off by about 300rpm compared to front mounted set ups. You might be able to pick up some lag starting in higher gears, but not from a dig.
You have to remember, it is sealed, doesn't take much time to pressurize the system as a whole, even when further away.
The main drawback I see, is the oiling sump, feed, and pump. Lots more parts to go wrong. But, if you have the dough, they make oil-less turbos also. Then you could turbo most cars in about a day or two.
Old 01-12-2017, 11:13 AM
  #79
braddman's Avatar
2005 SL65 AMG
What do you think you picked up in RWHP from just the downpipes?
Old 01-18-2017, 10:18 PM
  #80
DUDMD's Avatar
Not sure, probably not much if any on a stock setup.
But once you start maxing out the turbos with a tune and aggressive boost, they sure do help.
I'm starting a new build thread for my new setup, the engine/trans/abc system is removed as of today. Stay tuned for new build thread for full ABC delete and single turbo conversion.
Old 01-19-2017, 06:27 AM
  #81
braddman's Avatar
2005 SL65 AMG
I think the DPs will help a lot on the stock setup with a tune. I just did mine (had an exhaust shop do it) and I'm waiting for the tuner to come in today so I can slap a tune on it.
Old 01-19-2017, 02:02 PM
  #82
DUDMD's Avatar
I put down less than 10whp more after downpipes and icetank install, with factory tune.
I have my own Dyno Dynamics, no reason for me to fool myself. I did make very good power after the tune, especially maxing out the turbos and on MS109.
Old 01-19-2017, 02:07 PM
  #83
braddman's Avatar
2005 SL65 AMG
I'm not doubting that at all on the factory tune, but don't you think an aftermarket tune will wake that up? My BMW 335i was the same way, didn't feel much at all with downpipes until tuned.
Old 01-19-2017, 05:43 PM
  #84
DUDMD's Avatar
Yes. That's what I was saying, on a stock tune, the gains are not huge or any at all. But once you start maxing out the turbo, any bit of extra flow gets a good hp bump.
Old 01-20-2017, 02:25 AM
  #85
AMG-Driver's Avatar
SL65 R230
100-Cell Downpipes in combination with only a tune will gain approx.20-30 HP at the Crank.
As DUDMD said, more effect it has when you start opening up your intake and maxing out the turbos.
Old 04-22-2017, 02:21 PM
  #86
alexanderfoti's Avatar
2013 W204 C63 AMG, 2008 W221 S65 AMG
Firstly, amazing work.
secondly, I am slightly confused about something.
How do you stop the ECU being unhappy about the boost levels when using an aftermarket boost controller?
If you have your boost controller set to 7psi in the midrange instead of 15psi, how does the ECU not log underboost codes? Same the otherway round, if you build more boost at low RPM than the map is dictating?
Old 04-24-2017, 07:57 AM
  #87
braddman's Avatar
2005 SL65 AMG
Tune?
Old 04-24-2017, 07:58 AM
  #88
Tune?
Sure, but in the tune is desired boost level.
Ie @3500RPM w 100% throttle and in 3rd gear I want 20Psi of boost.
If the boost controller is set to 15psi surely it will log underboost codes?
I am not aware of a way to set a desired range of boost in the tune?
Old 04-24-2017, 02:00 PM
  #89
DUDMD's Avatar
I have the boost maps turned up high, as well as boost targets.
I haven't had a single issue with it throwing any overboost or underboost codes.
I'm still running max boost possible, except for I'm slowly ramping it up to 4K rpm, and after that it's whatever these tiny turbos could put out.
All that doesn't really matter anymore, as I fitted a single precision 7675 turbo, so now tuning is going to get weird but I don't think it will be difficult.
Old 04-26-2017, 11:57 AM
  #90
Aha fair enough. A (bad) mechanic told me they where very sensitive to underboost and would log codes quickly. Appears not to be the case.
Interested to see how your single turbo project turns out!
Old 07-03-2017, 09:54 AM
  #91
Few things.
1. most of the images have died on this thread
2. On the tune side of things, did your boost controller replace the factory one, or work with it?
Did you have to modify any torque limiters at all, or just the boost control maps to allow the higher boost pressure produced by the boost controller.
Old 07-04-2017, 04:22 AM
  #92
DUDMD's Avatar
I have yet to see an underboost code.
Old 07-04-2017, 04:25 AM
  #93
DUDMD's Avatar
Few things.
1. Photobucket went crazy and is demanding a $400 ransom to be able to host images and show them on the forum. I will wait a week to see if they come to their senses and decides on a reasonable price or makes it free again. If they still keep the insane cost, then I will have to switch the pictures to another hosting site and relink them all.
2. I modified the main torque limiter to match my power band a little bit better. Stock boost solenoid is plugged in but has no hoses going to it at all. The boost maps are pretty much stock, except for failsafes are turned all the way up.
Otherwise eboost 2, has it's own built up boost cut feature, and boost by rpm corrections to keep my boost the same/flat till redline.
Old 07-04-2017, 04:25 PM
  #94
Just spotted that, that's a bit ridiculous!
Thanks for the info on the mapping side, I thought as much.
Old 08-09-2017, 07:12 PM
  #95
BlownV8's Avatar
Received 1,075 Likes on 862 Posts
E55, GLS450, GL63, GLE350
Any track results yet?
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
Quick Reply: SL55/63/65/R230 AMG: DUDMD SL65 AMG - Build/Work Log
