SL55/63/65/R230 AMG: IC – extra fans on extra HE – which electric thermostat to choose?
Old Jul 5, 2017 | 07:40 PM
amok55amg's Avatar
SL55AMG + SL600 + E320 + A180
Looking into this cooling issue with the IC – going for upgrade with extra HE and Johnson pump and some extra fans as NikleinR6 did …. but he made a switch for turning the fans on and off which I do not want. I found a 6” double fan set with an electric thermostat but which temperature would be the best for activating the fans? I don’t want them to be running constantly – only when in traffic after a long pull etc.
180F/165F
160F/145F
140F/125F
Anybody having any knowledge about this?
NikleinR6 comments on the extra fan setup:
-Attached (2) 6" fans to the backside of the new large heat exchanger up front that are controlled by a switch hidden in the ashtray. I do notice a difference. It would take longer for the IAT's to drop once i got off the highway after a long pull, so i installed the fans. They help tremendously while i am sitting at redlights and moving slowly. They don't reduce the temps more than if i didn't have them, but they absolutely do reduce the recovery time it takes for the temps to drop back down after they rise
Old Aug 28, 2018 | 09:30 PM
Lolxa's Avatar
2010 Mercedes E550 4matic Sport P2, Driver Assistant, Night Vision, Parktronic and Panorama Sunroof
Also, can you move your seat forward and a perfect camera shot. It'll help to figure out what it does
