SL55/63/65/R230 AMG: Coolant visit workshop after heat exchager
Old Apr 14, 2018 | 10:27 PM
Woodpecker1's Avatar
2003 Mercedes SL55
Unhappy Coolant visit workshop after heat exchager
I'm trying to find out why I am getting this alarm off and on (Coolant visit workshop) after I installed my heat exchanger to compensate for the mods I have on my 03 sl55 I have bled all the air out and I have kept a close eye on my coolant level for the last 2 weeks and everything is fine no over heating or any other abnormal behavior I did have my car scanned with star diagnostic at my local indy and it came back saying cooling fan not working as it should so I replaced my cooling fan and I still get this alarm even though not as much, I have gone through all the scenarios, done lots of research including on this site only to find similarities but nothing specific to my issue so I guess my question is what would cause this after a heat exchanger install other than things listed above because this is when my problem started I guess if I can't figure it out I will take it in for another diagnostic but last time I did that it cost me a diagnostic fee, a $600 cooling fan and my problem still exist. any help would be much appreciated
Old Apr 15, 2018 | 12:09 AM
Joe Chu's Avatar
SL55 AMG
Do you have ensure and corrected coolant level?
What fault code stored in a vehicle?
Are you ensure the new coolant circuit of heater exchange correct ?
Old Apr 15, 2018 | 04:52 AM
2003 Mercedes SL55
Yes I have verified all of this and everything is correct and there are no fault codes
Old Apr 15, 2018 | 06:11 AM
Joe Chu's Avatar
SL55 AMG
How about the coolant mixture ratio?
If there is too lean (Tap water only), the coolant level fault message will light up! And also washer system.........
Actually, I don't ensure what fault message would be light up if the coolant level not correct, so you can unplug the connector of bottom of expansion coolant tank for test first!
Old Apr 15, 2018 | 07:58 AM
2003 Mercedes SL55
Ok I will look into the coolant level sensor and my coolant mixture is correct but not sure about the type of wash fluid but I know it's full, thanks for the input
Old Apr 15, 2018 | 08:54 PM
okbarnett's Avatar
Porsche guy who drives SL63 w/ perf pkg AND perf suspension
I think level sensor , its old and once it goes off it wont sense again
Old Apr 16, 2018 | 01:46 AM
2003 Mercedes SL55
[QUOTE=okbarnett;7431293]I think level sensor , its old and once it goes off it wont sense again[/Q
Ok I will change it next thanks for your help
