SL55/63/65/R230 AMG: Hi revving after valev cover casket
Old May 7, 2018 | 09:54 PM
Austinsec's Avatar
Sl55 2003
Ok , I did the valve cover gaskets on the car , went well now the engine revs high I found a vacuum line disconnected connected it , Now I get check gas cap blinking and engine check.
Please advise
I cant seem to find any other lines off.
Its a 2003 SL55
BTW Im on Long Island NY if anyone wants to burn a couple hours and help out you are welcome.
Old May 7, 2018 | 10:44 PM
Austinsec's Avatar
Sl55 2003
Does anyone have a picture of the surge tank location on the sl55 some say hoes is there
Old May 8, 2018 | 03:58 AM
desired_speeds's Avatar
2007 SL55 AMG
There is a hard line that goes into the back of the supercharger that runs along the back of the drivers side valve cover. One of the bracket bolts onto the valve cover sharing a valve cover bolt. From there you can trace it to where it goes into the supercharger. You can see it in between the throttle body neck and the drivers side surge tank if you shine a light at the right angle.
Old May 8, 2018 | 01:24 PM
Austinsec's Avatar
Sl55 2003
Is the location here where circled?
Any chance there is a picture of this somewhere , I cant pass inspection now with this issue.
I will attempt to find it but at a loss , I saw the bracket ant the pipe dont see anything disconnected
Here is a picture of the valve cove found online I circled a part is this the hose location?.
Old May 10, 2018 | 02:04 PM
2007 SL55 AMG
yes thats the area. it's a metal hardline that has a 90 degree bend into the s/c
Old May 10, 2018 | 02:05 PM
2007 SL55 AMG
