SL55/63/65/R230 AMG: What is best, easiest way to upgrade the heat exchanger on SL55?
Many people suggest that adding to the stock or upgrading the heat exchanger is a good idea, given my mods.
After doing some research, it sounds like there a number of options out there but they are usually best suited for the E55/CLS55 body and the SL platform is not so easy to work with due to limited space.
Is this really the case?
What would you recommend as being the best and easiest approach to upgrade the SC cooling of my car? Vendor? Size?
I am very DIY capable with lots of tools in my garage, but i am also trying to avoid the need to modify/butcher the front of my car too much.
Thank you in advance!
I'm only looking for $200 for it. I bought it for $285.
email me if your interested. i'm in NJ.
i'll be happy to sen you pictures if you want. It's at my Indy shop so Monday would be the earliest.
mark.deluca63@gmail.com
Regards,
Mark
Do you have any issues with your Race IQ tuned TCU still automatically upshifting at redline in manual mode? Tony has had my TCU twice and can't fix it.
Also... since you mentioned it, this may be a naive question, but what is the exact benefit from separating the SC cooling from the Engine cooling? Does it make a significant difference?
I understand that the heat from the engine will be separated in its own circuit, but will this make the SC run any cooler, given that it also generates plenty of its own heat and it will now have less coolant to work with?
The stock HE is separate from the engine radiator, but both heat exchangers are running the same coolant. If you separate the HE (and/or an additional HE) from the engine coolant circuit, this is what is meant by separating the cooling systems.
You'll have to move and wire tie some of the oil cooler hoses, I wrapped in foam pipe insulation. There are two supports on either side that you just
move a 1/2 inch at their top mounting point.
Position the HE so it is in the middle of the opening.
