SL55/63/65/R230 AMG: Sl63 plug replacement
Old Oct 4, 2019 | 04:49 PM
gqdabien's Avatar
SL63
Hello, I have an all stock 09 sl63. Are these the recommended plugs to get for direct oem replacement?
https://www.weistec.com/spark-plugs-m156-m159.html
Any tips on install for this car? I've changed plugs on toyotas in the past. Remove electrical coil , ratchet out plug with a deep socket and ratchet new one back in. Should be straight forward right?
Thanks!
Old Oct 5, 2019 | 07:03 PM
cybercord's Avatar
R231 SL63
Plug replacements
Should be straight forward. Just make sure you do not damage the coil and such. I'm sure your aware of this, but .
Old Oct 7, 2019 | 07:25 PM
marcd7tx's Avatar
E500 Wagon, SL63 IWC, E450 Wagon
Just make sure to torque to spec. Many a discussion here about using those colder plugs on a non-tuned car. If it's stock, stick with stock plugs was the jist of it.
Old Oct 9, 2019 | 12:35 PM
gqdabien's Avatar
SL63
Yes my car is non-tuned. I believe NGK ILZKAR7A10 is the plugs is what I should get then.
Old Oct 30, 2019 | 02:39 PM
gqdabien's Avatar
SL63
Anyone know what torque spec the spark plugs should be? I don't see it in the maintenance & service manual.
