SL55/63/65/R230 AMG: Oil Change Questions-‘05 SL55 AMG
Use new crush washers also. Poured in 8 quarts, started, looked for leaks all good. Next morning used dash tool to check oil level. Stated to add one quart to be at max level, which I did. I used Mobil 1, 0-40, Euro blend. Walmart had on sale like 22 bucks for a 5 quart jug.
Just re-read your post...about panels. I removed four 8mm bolts and bottom panel dropped down. Plugs are close together, but sumps look separate. Like a front sump, and a rear sump.
