Difference between M113.990 and M113.992 engines
Anyone know the difference between the engines for the E55 and the SL55´s?
Are parts like the water pump interchangeable?
Dont mean to bump up an older thread but did your new pulley wobble still? I got mine done at the dealership and it still wobbles, experience technician states that its normal for the m113 engine and not to worry about it. I was wondering what your impressions you had when you installed it on your car by yourself.
Yes, all harmonic dampers wobble. It's how they disrupt the belt vibrations from being transmitted to every other belt driven accessory.
-J
-J
Most parts are interchangeable. The I believe the most important differences between the SL's M113k and most others is in the oil sump, pan, etc.
-J
-J
