SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Drivers side Mirror
Old Feb 29, 2008 | 01:28 PM
doncale's Avatar
SLK230
Drivers side Mirror
Any one know how to change the drivers side mirror and the best place to buy it ? Mine is getting bubbles in it. (online replacment)
I just replaced the inside rear view from Donnelly corp...(that was easy and free).
Old Mar 3, 2008 | 11:30 AM
Taff's Avatar
slk
Tilt the mirror down so as to expose the back on top. Look for a little wire spring thing that runs horizontally across the back of the mirror glass. Lift that wire spring upward a little with a screwdriver to remove the glass.
Old Mar 20, 2008 | 10:48 AM
katika's Avatar
1999 SLK230 Kompressor
Sure, check out www.mercedespartssuperstore.com ($372.28) OR www.myeuroparts.com ($436.80); the part no. is 208 810 0121 (from my 1999 SLK - your profile did not indicate which year SLK you drive so the part number may be different if you own a 2001-2004 model, also known as the facelift models, because of some cosmetic & mechanical improvements to the older version, such as relocating the front fender turn signal light to the side view mirrors). You could always call a dealer and ask, or use the search feature by model year to find the right part number. Happy hunting and hope this helps you out.
Old Mar 22, 2008 | 01:32 AM
Buellwinkle's Avatar
When you say mirror, do you mean just the glass? Because I paid $45 for the glass at the dealer when it turned up missing one day. It's not the auto dimming kind because I don't think they had them that year.
Old Mar 23, 2008 | 06:26 PM
katika's Avatar
Yes, that part number is for the auto-dimming driver side glass without the mirror housing (which no doubt would be extra I presume). I almost swallowed my tongue when I saw how much it cost. Sometimes, all the whizz bang gadgetry on these cars will get ya!!!
