SLK/R170: BIG Brake installation
CLK320 & SLK230
Originally posted by Pelle75
$5,500 USD plus tax
Either Kleemann or Kicherer/AMG boster kit. Then Supersprints mainfolder and maybe Väth intercooler then I should have aprox. 250-260 HP.
$5,500 USD plus tax
will u test ur car on 0-60 and 1/4 miles soon ???
pls let us know the result , thx
MB SLK 230 kompressor -01, MB C32 AMG -02
Originally posted by Brian_R170
I'm curious to know what the Kleemann or Kicherer kits do that others don't. I've never seen or heard of an SLK230 that would break 250hp without either a displacement increase, larger supercharger, or addition of a turbo.
Either Kleemann or Kicherer kit break 250 hp if you read what else I'm going to do you will probaly notice that I will change more than just the boster kit
Boster kit ~ 230-235 hp
Supersprint cat-back, mainfolder and no cat ~ 5% more HP
Väth IC and BMC CDA box or open filter ads additional 5-10 hp
Then I should have about 250-260 HP
Originally posted by Supra
sounds very COOL .... 250-260HP , ^^
Not yet the car is still original
1 Post
'02 SLK32 AMG
Engine tuning modifications don't add up together the same way they do separately. For example, if an intercooler modification adds 10hp and an exhaust modification adds 10hp, then together they will probably make only 12hp to 15hp instead of 20.
Still, Euro-spec SLK230s have 7hp more than US-spec SLKs to begin with, and alot of SLK230 owners will be interested in your results. Please keep us updated.
The car has 197 HP stock I dont think its impossible to get 250 HP out of the SLK with minor modifications.
Using the boost kit along with a header (esp no cat) and a mild ECU tune, air filter and you can easily have 250hp at the crank- our C230 Kompressor coupe has this treatment.
Great Dog BTW
Great Dog BTW
#34
I have had several request to post the MIL cure for missing cats. This modification is for off road use only, never remove the cats from a car you intend to use on public roads. In the USA its a felony, I assume no liability for broken parts, bad installations, general malaise etc. YOU ARE ON YOUR OWN!
#35
For track use only
