SLK-Class (R170) 1998-2003: SLK 200, SLK 230K, SLK 320
SLK/R170: Speedometer, BAS/ABS/HandBrake lights
Old 08-10-2017, 07:38 AM
jovaro's Avatar
Mercedes SLK200 R170 1999
Good afternoon, I drive a SLK200 r170 from 1999 with great pleasure, but a few days ago me Speedometer stopt working and all brake lights like BAS/ABS/Handbrake and Brakepads are on. After using my Autel 702 I changed the rear left speedsensor, but the problem is still there. I have changed the brakeswitch at the pedal and alle brakelights are working. Any suggestions where to look? Thanks in advance! Jos
Old 08-10-2017, 03:11 PM
Plutoe's Avatar
Received 1,019 Likes on 947 Posts
1999 E300TD
Have you cleared all the faults!
Old 08-10-2017, 03:32 PM
jovaro's Avatar
Yes I erased the faults but they come back straight away
Old 08-10-2017, 03:42 PM
Plutoe's Avatar
1999 E300TD
Then you haven't corrected the problem and or your crapper scanner can't read the chassis faults. Get a new reader or find someone with the experience!
Old 08-20-2017, 02:18 PM
BLUESHERM's Avatar
GLK350
ABS EBS POWER STEERING INOPERABLE LIGHTS ON
I have a 2010 GLK350, ABS,EBS POWER STEERING INOPERABLE lights come on as soon as I drive over 10mph. Everything is functional but found this appears to happen when you are 500 miles from service being due. The fix, you have to go into service mode, put key in position 1, then with miles displayed, hold left position select button down until trip is highlighted, touch phone button for a second then hold ok button for 5 seconds. "ASSYST PLUS" should be displayed, select it by pressing OK. Go into "DYN0 TEST" and select ok to turn on. FO for a short drive while in DYno test, you will get a message the ABS,EBS and power steering are disabled while in test mode but they are functional don't worry. Pull over or head back home, you will need to turn off "Dyno Test by the same process you turned it on. You can also reset your service light while in "Assyst Plus"
GO for a test drive and all should be reset, I've had this happen to be a few times after my car sat at the airport for a long period while out of town. One thing that appears to trigger this is when service due for "service B" gets to within 500 miles, or so it has happened for me. Hope this is useful to all you DIY's Mercedes owners.
Old 08-20-2017, 02:45 PM
jovaro's Avatar
Speedometer ABS/ASR
Good news, everything is working again. I removed all the electronic modules of my slk and when i tested the K40 relais unit, I found out that 1 relais was not working. I ordered a new one for 3 euro and replaced it myself and now all problem are solved. 😊
googler (08-21-2017)
Old 08-21-2017, 03:50 PM
googler's Avatar
MB SLK
Thumbs up
Well done, and thanks for informing us. That K40 seems to crop up frequently as the culprit! You did well to get a new one so cheaply- hope it stays healthy
Quick Reply: SLK/R170: Speedometer, BAS/ABS/HandBrake lights
