hubcentric rings
Does anyone know the bore of the car? i think i need hubcentric rings, cause its vibrating like no other.
Originally Posted by Freddyboi
(Post 2149928)
Does anyone know where i can get it? Also, if the bore of the car is 66.7, would anyone know what the bore of the iforged rim is? thanks
(Post 2150710)
What is a hubcentric ring?
Originally Posted by Duo-Art
(Post 2151463)
http://www.1010tires.com/images/acce...ings_large.jpg Hub centric rings are manufactured so that when they are installed on a vehicle, the wheels are located directly off of the centre flange of the brake drum or rotor. This is done to insure that the outer beads of the wheel are concentric with the wheel bearings. The result is a much truer, better balanced tire/wheel assembly. This is very important with modern high tech suspension systems. Link here. http://www.1010tires.com/hubrings.as...FSApSgodPUZhAg |
Ynot, thanks for the explaination. I thought that was their function but I wasn't sure.
(Post 2150710)
