SLK-Class (R171) 2004-2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
SLK/R171: Air Pump P0401 Code - Relay help?
Old Nov 17, 2012 | 07:59 PM
Dominic2's Avatar
SLK 280
I am having an issue with my airpump on a 06 skl280. The pump is fine when bench tested but does not appear to ever come on and throws a p0401. On the attached fuse panel diagram I verified fuse 65 is good, but believe it also uses a relay. Can anyone identify which relay it may be in the attached diagram?
Thanks!
Dom
File Type: pdf
Old Nov 18, 2012 | 02:14 AM
Dominic2's Avatar
SLK 280
Its relay "O".
Old Nov 18, 2012 | 08:13 PM
Dominic2's Avatar
SLK 280
wow. what a worthless place this is.
