SLK-Class (R171) 2004-2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
SLK/R171: SLK 350 engine noise on startup
Old Jul 4, 2013 | 05:47 AM
crittenden350's Avatar
350slk
My SLK 350 engine has always been noisy on startup. The noise is a harsh light rattle from the top end which disappears after 2- 3 seconds. The engine is then quite whilst running. Mileage is 50K & MB serviced from new. It seems that the top end is not getting lube oil at startup. Have seen posts on the non return valve in the oil filter housing being faulty allowing oil to drain away from the cylinder heads. Any ideas?
