SLK-Class (R172) 2011-Present SLK200, SLK250, SLK350, and SLK 55
SLK/R172: SLK AIR SCARF
Old Sep 15, 2020 | 06:05 AM
benzboy85's Avatar
2014 R172 SLK 200 & 2015 GL350 D
SLK AIR SCARF
Hi,
I have a 2014 SLK 200 , the airscarf works perfect with the roof up , once the top goes down and I remove my foot of the brake it turns itself off.
The Car is currently at the dealer for the past 2 weeks and they cant find the issue, has anyone had this problem ? and do you have any advice on what could be wrong?
Old Nov 16, 2020 | 05:07 PM
Paul7's Avatar
E200 Convertible
Question
I have exactly the same problem on E200, if the roof is down and I start driving, airscarf turns off. Although it works without problems with a closed roof. Have you found a solution?
Old Jan 30, 2021 | 06:05 PM
Paul7's Avatar
E200 Convertible
Two months later, I solved this problem by replacing the Airscarf control module that was in the trunk behind the trim (on the right side)
I posted information about that on my website: https://blogpavel.com/2021/01/30/airscarf-fix/
Airscarf module part number is: A1729000402
