Brake Upgrade from ///AMG Performace Package 030 (With PartNumbers and Prizes !!!).
Brabus K3
Hello,
If you want to upgrade your brakes to performance package 030 (only front brakes change), here is what you need:
2* Front Discs: A 209 421 01 12 (2*812€)
1* Disc inside protection plate: A 209 420 07 44 (44€)
1* Disc inside protection plate: A 209 420 08 44 (44€)
1* Front Caliper: A 003 420 67 83 (561.45€)
1* Front Caliper: A 003 420 68 83 (561.45€)
Brake pads are the same that original A 004 420 50 20 (149€)
If I'm not wrong new discs are only perforated and not perforated and sloted like normal SLK55.
Stock are:
13.4" 340mm compound/composite two-piece perforated and ventilated front discs with AMG 6-piston fixed front calipers.
030 are:
14.2" 360mm x 32mm compound/composite two-piece perforated and ventilated front discs with AMG 6-piston calipers.
All 20% lighter than normal ones.
At rear they are the same:
13.0" ventilated rear discs with AMG 4-piston calipers.
I attach some photos. I don't know why some are sloted and some not and why the non sloted the perforated pattern is different, but I think the only one of the 030 is the last one that don't have the wheel.
Best Regards,
Ruben.
Stock are:
030 are:
Best Regards,
Ruben.
SLK 55 AMG
Thanks for the info. Pretty expensive stuff... I wonder if the improvement is really as big as they say. I find my brakes to be pretty damn powerful to begin with, would seem to be that the change is marginal.
Brabus K3
For me it will be very usefull if someone can post some close pics of his brakes telling me the year of the car. (I need normal and 030 pics).
Thanks.
Thanks.
Brabus K3
Here the comercial info:
When you have such remarkable potential acceleration and speed at your disposal, you need high-performance brakes.
Which is why the SLK 55 AMG is fitted with a composite brake system at the
front axle. The cast disc is connected to the aluminium bowl and supported both axially and radially by floating bearings.
This means that it can expand under high heat without distortion. The effect:
optimum fade-resistance, less brake judder and outstanding deceleration –
thanks also to the 6-piston fixed callipers at the front brakes, which are state-ofthe- art in this class.
Originally Posted by Shinigami
I find my brakes to be pretty powerful to begin with, would seem to be that the change is marginal.
Brabus K3
Originally Posted by dinko
SLK55er, they 030 brakes are slotted... I think they would benefit you on the track as well
Dinko
Dinko
Best Regards.
Can someone answer me this questions:
The stock discs come? sloted? perforated? sloted and perforated?
The 030 discs come? sloted? perforated? sloted and perforated?
CLS55
The picture above is a 030 car.
To answer the question:
Stock: slotted & perforated 13.4"
030: slotted & perforated 14.2" - 2 piece rotor (according to the info above)
My take on this:
When I do decide to upgrade, I would purchase the Evosport rotors (which are even lighter) but would have to purchase the new calipers. I am not sure, however, if this is possible just yet.
Dinko
My take on this:
Dinko
Brabus K3
My take on this:
Dinko
My take on this:
Dinko
As far as I know you can purchase the calipers and put the evosport rotors for the E55, CLS55, etc...
Then I don't understand if stock and 030 are perforated and slotted why I have pictures of the SLK55 with the discs only perforated and not slotted. Any idea? (I posted some on this thread).
The 030 calipers should fit the 18' rim at the limit, no?
Do you know if this Brabus Monoblock VI multipiece rims will fit a 030 car?
622-858-30RDK 8,5J x 18 H2 offset 30
622-958-35RDK 9,5J x 18 H2 offset 35
(Brabus says they don't fit E55 that has 8 piston front calipers with 14.2 Discs).
Best Regards.
CLS55
Originally Posted by rubensans
Thanks;
Best Regards.
Best Regards.
What I wonder is this now: If the upgrade consists of a 6 piston caliper, why not upgrade to a 8 piston caliper? Can anyone chime in on this?
Dinko
'06 slk55
So in total, that's about 1 or 2 lb for the two front brakes put together?
It just doesn't make that much sense... and as said before, I am quite satisfied with the stopping power of the standard brakes. I think the brake upgrade may only affect those who track ALOT and not just the occasional AutoX, etc.
2005 SLK55 AMG
2005 SLK55 standard AMG brakes
2005 SLK55 standard AMG brakes, sloted/perf'd
Rear then front. Sorry garage is dark, had to use flash, so not great photos.
