Brake Rotors
Former Vendor of MBWorld
Brake Rotors
Message us for a quote
Premium Cross Drilled and Slotted Brake Rotor Kit
This kit was designed with the perfect combination of brake rotor and brake pad for dramatically improving stopping power over the factory braking system. Each brake rotor consists of curved slots machined off the edge of the rotor to improve braking performance. Each curved slot also removes water, dust and debris while cooling the temperature of the pad surface. All Cross-Drilled holes are chamfered and perfectly sized to give the maximum ventilation without structurally weakening the brake rotors. We selected premium semi metallic brake pads because of there high heat and friction level. The cross drilled and slotted brake rotors included in the kit are sold in pairs. The rotors come zinc coated in either black or silver to help prevent rusting and give you a performance race look. We include a free lifetime warranty against defects in materials and workmanship and a lifetime warranty against warping and cracking.
Machined and plated in the USA
Available without pads also.
I need rotors ASAP
I have a 2014 W218 CLS63 AMG all whee drive. I need all 4 rotors can you please provide a quote.
I have the Disc Italia Hyper Ceramic pads on my car for over a year. They make a big difference but still leave a light colored dust on the rims. This Winter I went several months before it started to look dirty. Just cleaned the car and wheels today using a new method. First power wash using Simple Green and rinse off. Then spray the rims with Iron-x and let it combine with the dust for 3-4 minutes then scrub with wheel brush and power wash everything off. The rims look like new!
