Carlsson C-Tronic lowering module
Old Feb 7, 2010 | 03:29 PM
AMGPilot's Avatar
2004 E55
Module only you will have to get the harness from Carlsson.
I'm asking $500.
Here are the details
The C-TRONIC SUSPENSION is plugged between the level sensors of the wheels and the ABC/Airmatic control unit. The sensor signals are modified with an offset. That is to say that a voltage is added or subtracted to the sensor signal.
In case of active lowering the C-TRONIC is changing the sensor signals in such a way, that the vehicle level is lowered up to –30mm.
Also, all Carlsson products are TUV certified for use and application by the German government.
Lowers the car approx. 30 mm for cars with DC AirMatic or ABC
Fits:
2003+ W211 with Airmatic Suspension (E55/E63)
2003+ SL with Airmatic Suspension
1998-2006 S-Class
1998-2006 CL-Class with ABC Suspension
Intelligent adaptation of spring travel, sporty look by lowering up to max. 30 mm, improved driving dynamics through reduced roll, and the best of it all: the wiring harness, is not only reliable but quick and easy to plug or to return the suspension to its original condition and settings at any time. (no cutting wires or splicing into the factory harness, just plug and play)
Ride comfort - As a rule, conventional systems for lowering vehicles with electronic suspension systems do no more than lower the centre of gravity. By contrast, the Carlsson C-Tronic Suspension not only lowers the centre of gravity but also, thanks to its sophisticated technology, reacts intelligently to the changing road conditions.
On poor surfaces where the suspension jounces continuously, the vehicle height is automatically raised to ensure sufficient spring travel for even ride comfort. This demand-responsive system is controlled electronically and automatically so the driver enjoys a high level of ride comfort in all situations. The permanent data synchronization with pre-set values ensures split-second adaptation to the road conditions prevailing.
Quick and easy installation - Thanks to the tried and tested C-Tronic connection technology for the wiring harness, installing and removing the Carlsson C-Tronic SUSPENSION is not only reliable but quick and easy. For customers, this means only a short fitting time and, therefore, low workshop costs (or you can even install it on your own with only minimal technical knowledge). Furthermore, the vehicle can be returned to its original condition at any time.
Old Feb 9, 2010 | 01:38 PM
AMGPilot's Avatar
2004 E55
Bump
