e63 2 piece rotors
Old Jan 16, 2011 | 03:02 PM
320 dreamer's Avatar
2003 porsche 996 turbo
e63 2 piece rotors
well i was hoping to use these for my bbk upgrade but they wont work for my application. so here they are up for sale. 400$ plus shipping. they are heavy , 30lbs each so i will need your zip before i confirm a shipped price.
heres the link to the original sale pics are the same these havent been used
https://mbworld.org/forums/suspensio...1-02-12-a.html
i would consider a swap for a set of clk 63 hats and some shipping cash
before you ask i can tell you they should fit the
07 sl55
09 sl63
08 cls63
08 e63
other than those cars i cant help with the fitment rotor height is 64.7mm
Old Jan 17, 2011 | 02:38 AM
Dan Wang's Avatar
E320CDI, CLK55, and a Smart
FYI, to help with the shipping costs, you can use the postal service flat rate box up to 70#.
Old Jan 17, 2011 | 08:37 PM
i will try that but not sure they will fit in the box, they are pretty huge!
Old Jan 18, 2011 | 09:37 PM
gonzales25's Avatar
Slow
Man...Sorry they didn't work out for you.
Old Jan 19, 2011 | 07:56 PM
its no biggie bro. no fault anywere. if i can find the clk63 or slk55 hats i can use all the hardware and the rings from these. if not ill have to buy a set and sell these. all part of modding were no one has modded before!
Old Jan 19, 2011 | 08:02 PM
wally AMG's Avatar
MB
I'm the first in line for the rotors right?
Old Jan 19, 2011 | 09:04 PM
i have feelers out everywere for some hats but you got first dibbs
Old Jan 22, 2011 | 12:47 AM
WaveyKat's Avatar
Something Slow
are these the same size at the CLK63 030 package?
Old Jan 22, 2011 | 07:44 AM
yes 360x36mm do you have any clk63 hats you want to sell?
Old Jan 22, 2011 | 12:30 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
CLK55/CLK63/SLK55 used a 360x32mm rotor.
Dreamer, are you even sure if the hat bolt patterns would line up? You might need to make yourself some custom hats. There is one or two ppl on the W203 forum that have done the swap, might want to see what they did to accomodate the 26mm or so height difference.
Old Jan 22, 2011 | 03:33 PM
the clk63/slk55 rotor is only 3.3 mm offset more than my oem rotors. using the clk/slk hat i can use the rings and hardware from these rotors and have an almost oem fit. bolt pattern is the same.
for now im going to keep searching and hold on to these rotors
Old Jan 22, 2011 | 06:30 PM
Viper98912's Avatar
I guess the question is if both hat-to-rings have the same bolt pattern. Also, what is the 8 pot front offset, unless you plan on using some custom brackets. Good luck man, look forward to seeing the results.
Old Jan 22, 2011 | 07:14 PM
hat to rings same pattern. as for the caliper offset that i wont know until i have a rotor to mock them up with. rear setup is ez peazy only need to trim the backing plate and its bolt on.
Old Feb 19, 2011 | 03:18 PM
bump to the top. i have sold the 8 pot caliper so dont need these rotors. 450$ shipped in the usa.
Old Feb 27, 2011 | 09:43 PM
bump for the week and a couple pics
Attached Thumbnails e63 2 piece rotors-hpim0537.jpg   e63 2 piece rotors-hpim0536.jpg
Old Mar 7, 2011 | 08:14 AM
bumpin for the week
Old Mar 14, 2011 | 11:39 PM
wildcardfox's Avatar
mustang
Pm sent. I'll take em
Old Apr 16, 2011 | 11:36 PM
midnyite's Avatar
AMG GTS
still for sale?
hit me up if available
Old May 3, 2011 | 02:25 PM
Tom_Boy's Avatar
2003 CL55
Lemme know if they are still available please.... Will send a PM...
Old May 5, 2011 | 08:20 AM
calipers sold . mods feel free to close the thread
Old Nov 1, 2011 | 07:35 PM
khelawanb's Avatar
2006 CLS500 with 55 AMG motor, 2008 Infiniti G35, 2000 Plymouth Grand Voyager
I'm guessing you meant to say Rotors are sold? But if you still have them I will buy them.
Old Nov 1, 2011 | 09:51 PM
sorry bro. yes the rotors are sold
