FS: Rare SL55 Evosport lightweight rotor hats.
Old Oct 10, 2011 | 10:42 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
I have a brand new set of rear Evosport aluminum rotor racing hats for the SL55. These are the hats only and you can put them on the race rotor of your choice. Brembo and many others have the rotors. These will take about 8-10 lbs off each rear wheel. Increase acceleration and cut down on wheel ineria.
List price is over 600.00 for the set. I need to get 450.00 to your door in the USA mainland.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Oct 12, 2011 | 01:25 PM
komp55's Avatar
ML550
What size discs can be used with these? Stock calipers only?
Old Oct 12, 2011 | 02:10 PM
PLATINUM SPONSOR
2003 CL55
They will bolt on to any rotor/disc that has a 10 hole flange to mount the hats on. The hats fit the rear of a SL55. Brembo and others sell extra rotors. I assume evosport does too.
__________________
www.ultimatepd.com
