FS:W202 Complete Suspension Lowering Kit Vogtland, Bilstein, CamberArm, SpringCompres
Up for sale is a w202 lowering kit. It was installed on a 1999 Mercedes C280. It will fit all 1997-2000 C280 and C43 AMG.
It will also fit 1997-2000 C230 but you may want different spring pads to lower car further since your engine is not as heavy. It would fit 94-96 pre facelifts with the spring pads provided. Everything else would be a direct swap.
I have vogtland springs with #2 pads in front and #4 pads in rear. Bilstein sport plus shocks, diy camber arms made by many on the forums, some hardware (you may want to get new bolts) I have part numbers upon purchase, and of course a Mercedes OE spring compressor.
New this would total to around $1000++ or so USD.
All have about 10k miles on them. Make the ride extremely fun when combined with good tires.
This is everything you need to lower a w202 properly.
All you need is basic hand tools and a jack for install if you buy this complete kit. Took me about 9 hours total to do all 4 corners with proper lubrication and assembly. Less
http://www.ebay.com/itm/-/272785212523?
