**FTP I/C Trunk Tanks **CLICK**Product Release**
Former Vendor of MBWorld
Fabtech-Performance Is proud to introduce the only bolt in and go trunk Tank I/C system in the marketplace for any Supercharged AMG platform. This system has a total fluid capacity of 5 gallons!! And it has successfully lowered our IATS at WOT down to 118 on a 90 degree day during a PULL!!. Cruising IATS stay 10 deg above ambient at all times!!
We are seeing 10Deg above ambient with a 180mm pulley normal driving, Freeway etc. A 50 MPH to 140mph pull on the street we max at 136 deg and recover back to normal within 30 seconds
THIS TRUNK TANK WORKS, AND COOLS THOSE IATS AND RELEASES YOUR AMG'S TRUE POTENTIAL!!
ADD ICE we are seeing 20 deg below ambient for about 5 mins or a few pulls!!!!**
CONTACT
Steve@fabtech-performance.com
614-638-8732
Product Details:
The Fabtech-Performance Trunk Tank system is an ESSENTIAL modification for the M113K Platform, and is custom made to fit below the stock carpet in a W211 trunk retaining a STOCK appearance. Our system not only splits the cooling system so you are not running 190-200 Degree engine coolant through the Supercharger, but it also allows you to add Ice for drag racing and run temps at or Below AMBIENT! This system frees up Horsepower that the computer pulls away because of high Intake air temperature's, and successfully gives you a faster ET/MPH espicially while "Iced down".
System Features:
Precision Tig welded Aircraft grade 6061 Aluminum 3.5 Gallon Tank **LIFETIME Warranty against Workmanship defects!!.**
DETAILED INSTALL GUIDE
2000 G.P.H in tank Pump
Aircraft grade Aluminum Weld fittings
Gates PREMIUM 3/4 inch Heater hose Adds 1.25-1.50 Gallons
All necessary Clamps and Fittings needed for install
Self tapping screws and cushion clamps for Ease of line pluming
1/2 Drain Valve with Drain tube
Optional Accessories:
-10 AN black anodized Fittings Add $60.95
-10 AN Stainless Braided Line add $199.95
Flat black/Gloss black Powder-coating Add $85.95
Price: $529.95
Thanks for looking at our products!!
not all included parts are pictured, actual results may vary based on Pulley size,Tune, Climate. DA, Cooling system etc. Tanks are built to order based on your specs. We can build to any configurations!
CONTACT
614-638-8732
Product Details:
System Features:
Price: $529.95
