::ECS Tuning:: Engine Balance Shaft Kit For Your W212 E-Class With M272 V6
Former Vendor of MBWorld
2012 SLS AMG
Click HERE to order or for more information.
Only - $137.53*
The balance shaft in the early Mercedes-Benz M272 V6 engines was known to have problems due to soft metal being used in the manufacturing process of the timing gear. Over time, this gear wears down, causing timing to be thrown off.
ECS Tuning offers a genuine Mercedes-Benz replacement balance shaft kit complete with the updated timing gear to remedy the situation, a new rear counterweight and counterweight securing bolt and at a fraction of the cost of buying these same parts from the dealership.
*Price subject to change.
2012 SLS AMG
5Hundred,
Since you have a 2010 model year car, it is unlikely that you will experience the failure of the balance shaft sprocket due to soft metal. This issue was corrected by then.
However, the most likely first symptom you would see of this issue would be a check engine light with a P0016 or P0017 code indicating Crankshaft / Camshaft Position Correlation Error.
If there is anything else I can help you out with, please feel free to post or send a PM!
