Speed Tuning USA - Dyno for 55 engine
A.
*** Graph attached in CLS Forum
https://mbworld.org/forums/search.php?searchid=2734701
Second, not all 55K motors are the same. Mine is an '06 built in '06 and I do not believe that there is yet a good ECU tune for that. If your CLS is also newer, be careful.
Ask them what the details are on the one they posted. What MY was it, etc.
Last thing, i say either get your hardware first, or make sure you can go back and reprogram it after. The ECU changes will only give you significant gains if they are set based on the hardware. To do the ECU before the pulley is almost silly.
Ecu alone won't gain you anything except a crisper throttle response.
