S>O>S Need to find TCM Board (Shift Module)
Let's just say my Saturday night was a complete nightmare although I will admit I was planning on heading into Boston for a few cocktails after our win over the Bulls
But I didn't even make it on the highway long story short I spilled my redbull over the shifter causing it to malfunction. I've read another post that it's a very easy DIY so I'm up for the task to replace this piece.
However I can't find this Shift Module for sale anywhere on the W.W.W
If someone can post a link or at least guide me in the right direction as I'm trying to avoid calling MB.
Thanks in Advance
-Armani
Thanks in Advance
-Armani
Ok guys,
I found the part it's actually called Gear Shift Assembly Part Number # 210 267 05 24 It was actually pretty easy DIY task. From what I understand the Stealer charges 1k for this job. I have attached the DIY link so in case someone accidentally spills their Redbull on the Shifter by accident
It took me a while but I was able to find the part for $387 so be warned be careful not to spill anything- I could clearly see the fried circuit board when I took it apart. Sorry for the bad pics PDA cell
Most place's where charging $550 for this part fyi
ETA 2 Hours to remove and install new part
http://www.benzworld.org/forums/w210...e-replace.html
*Side note make sure when you remove the clip that secures the linkage on the bottom rest it on the side and tape it so that It doesn't fall into the Abyss
lol yup... guess the Beast was thirsty
Waiting for Ohlord for price check
If anyone has questions on this in the near future PM me
-Johnny
-Johnny
2008 EVO X GSR
Does anyone else shifter surround, the strip that goes around the shifter and is plastic on top of the wood, pop up? mine is always popping up and just a needs to popped back into place...
I was able to buy a used one from a member in the regular W210 Forum for $130 I posted this topic over there as well.... \It's used but don't need a new one as its only function is the circuit /
Yup it's in your head. There is nothing you can tighten in there trust me I know. It was soooooo hard to remove the 3 bolts to remove the actual shifter. Also unless you feel LOTS of play when shifting gears the only culprit would be the rubber piece that connects to the actual linkage/shifter and this piece you can buy. ( intensive research on this damn shifter )
a or b
A. Your plastic piece clips are broken
or
B. Prior owner may have bought aftermarket
Easy fix buy OEM should be able to find it on Ebay... cheap anyway....I came across a few
Ok guys,
