It's back: ABS/BAS/ESP
It's back: ABS/BAS/ESP. This issue first appeared about six months ago. Back then, the remedy was to restart the vehicle, and turn the steering wheel completely to the left and then to the right. This held until recently, when the three malfunctions reappeared, but on a more regular basis. Last week, after reading through the forums, I decided to replace my battery. It was over three years old, and when tested appeared to be holding a low charge. The vehicle now runs stronger, and my issue appeared to be remedies. Today, it came back: ABS/BAS/ESP. My best guess would be to replace the voltage regulator and/ or the alternator; or the brake lamp switch. I have noticed that this issue appears on long drives, or hard drives where I apply the brakes more often. I am obviously beginning with the cheap do-it-yourself remedies, but I am getting frustrated in the mean time. Can someone please shed some light on this issue or their remedy to this issue. Or is this a common malfunction that is a innate malfunction in itself. :nix: Almost forgot; my 00 E55 has only 63K on the clock.
Originally Posted by ruBENZ
(Post 3529343)
I bet it's your brake switch. My came on while a few week ago while i was braking hard up and down the hills of down town Seattle. When i restart the car it went away. I replaced the brake switch anyway and it hasn't come back since. |
Originally Posted by Peter_02AMG
(Post 3529411)
It happens to mine every once in a while when I back out of my very steep driveway
happens on and off on mine, bought a breakswitch, anyone know exactly how to install it?
Also check your brake wires. It's possible that the wires are exposed and is getting short circuited.
(Post 3529411)
ABS/BAS/ESP ON MY 2000 E55
ABS/BAS/ESP ON MY 2000 E55 W/ 104K MILES, POPPED UP.. IT HAPPENED BEFORE BUT, WAS ABLE TO GET RID OF IT , BUT NOW. ITS WORSE. NOW ONCE IT POPS..THE CAR DRIVES DIFFERENT, IT DOES NOT SHIFT, THE MILEAGE STOPS, THE SPEEDOMETER STOPS WORKING. .. WHATS THE CAUSE?.. HOW CAN I FIX THIS. I'VE BEEN READING THREADS HERE, BUT SOME DONT WORK.. WHERE IS THE BRAKE SWITCH LOCATED AT?.. THATS ANOTHER OPTION I WOULD LIKE TO TRY, I COULD EITHER TRY CLEANING IT, OR REPLACING IT. THANK YOU IN ADVANCE!!
Originally Posted by RAEBENZE55
(Post 3560573)
Good luck :y |
(Post 3529343)
I repair industrial electronics for a living and with my experience with that I'll tell you that you may solve the problem for a while by replacing a switch, but if it's a wiring issue which mine was, replacing a switch everytime it happens will only bring you closer to more severe problems down the road (fire, wreck, etc.).
Originally Posted by CONDEMNED
(Post 3564525)
Originally Posted by SleepersRock
(Post 3564962)
Hopefully its not a wiring issue and just the switch, which was clearly getting stuck when depressed in my case.
:topic:HOW DO I DISCONNECT MY BATTERY TO RESET MY ECU? ISN'T UNDER A SEAT OR SOMETHING?:confused: |
(Post 3566992)
I must have missed the part about the switch being stuck ha ha.:slap: In that case not much to worry about.
(Post 3567291)
It was the switch. The original OEM has a design flaw; the replacement OEM addressed the flaw. :D The battery is located under the rear seat passenger side. There is a release clip on both corners of the rear seat. Release, and remove seat. Disconnect the battery. Wait at least 20 minutes (some folks prefer overnight), then reconnect the battery. WARNING::eek: Have your Radio Code on the hand, and be prepared to reset your windows, seats, and sunroof.
(Post 3567857)
Reset the sunroof??? I was unaware of any personal settings for that, what are they?
| All times are GMT -4. The time now is 05:18 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
