I NEED HELP ASAP!!!
Old Jul 16, 2009 | 07:05 PM
LeeRod80's Avatar
99 E55 AMG
Unhappy I NEED HELP ASAP!!!
I bought a set of updated Euro tail lights. After I installed the passenger side I gave it a test. The signals worked on both sides, aswell as the reverse lights. Even when I turned on the headlights, the rear lights worked also.
Then I ask my brother to step on the brake. Both Driver's side and middle light bar light up. Nothing on the newly installed light. So I removed the bulb and replaced. Asked him to try again. NOW, no brake lights work. Everything else works fine. Just brakes. I get a CEL stating: LIGHT BULB/BAS/ESP/ Then ABS something something!
I checked every single fuse. All good. I even replaced the bulbs.
WHAT DID I DO WRONG??!??? WHAT BLEW, A FUSE, ETC?
Grrrr..
PLEASE HEEEELP!!
Old Jul 16, 2009 | 08:22 PM
MR888's Avatar
E55
pic of tails?
Old Jul 16, 2009 | 10:14 PM
LeeRod80's Avatar
99 E55 AMG
Help me first. lol
Old Jul 17, 2009 | 01:01 AM
armaniE55's Avatar
2012 CLS63 AMG
Arrow
Nope no help....Pics First..than you get help
Not sure what..... check fuse's post this in the reg. W210 I'm sure Ohlord can chime in and assist
Johnny
P.S
Bought New Rims Today
Old Jul 17, 2009 | 04:22 AM
desired_speeds's Avatar
2007 SL55 AMG
You have to make sure the sockets have contact with the metal board. maybe you didn't twist it on all the way? did you get OEM ones or aftermarket?
Old Jul 17, 2009 | 09:27 AM
saintz's Avatar
GL450
I would unplug the battery and wait (I'm assuming you have your radio code). Remove the new lights. Install your stock lights, reconnect the battery, and see if they work now. You'll need to resync your windows and turn your steering wheel lock to lock to reset the BAS/ABS lights. See if that works.
Old Jul 17, 2009 | 11:05 AM
armaniE55's Avatar
2012 CLS63 AMG
Cool
something funky is definitely going on he shouldn't recieve bas\asp light warnings by changing the tail lights. definitely reverse your steps and put back the original ones to see if you still get the warning but now you may have to disconnect your battery before putting the regular ones back on to reset your bas\asp warning. unless you have a obd II scanner to reset yourself without dis connecting the battery.
I'm willing to bet its your aftermarket rice burner Japan tail lights lol
I have a OBD II scanner if you want to come by. I can take a crack at it
I get off at 6
let me know ...
Johnny
Old Jul 17, 2009 | 12:39 PM
saintz's Avatar
GL450
I've seen reports before of bad brake system components (brake switch) triggering the BAS warnings. It's a break system failure, after all. If you switch your stock lights into a new housing, I don't see an issue. But replacing the entire light, including electronics, I can see how you get a CEL.
Old Jul 17, 2009 | 03:48 PM
LeeRod80's Avatar
99 E55 AMG
Thanks for the input. I got them working. It was the fuse, and I had to play with the bulb sockets a bit. Apparently our W210's have a THIRD fuse box inside the car, to the left of the steering wheel. I did not know this. WTF! haha
Special thanks to my bro Armani. I couldn't have figured it out without you man!!
JEAH!
Old Jul 17, 2009 | 04:42 PM
2007 SL55 AMG
looks sexy!
Old Jul 17, 2009 | 04:44 PM
armaniE55's Avatar
2012 CLS63 AMG
JEAH!
good thing you fixed it you almost needed a new engine.. lol
Just so you know phone support is extra
All good... call me later to figure out the housing
Old Jul 17, 2009 | 05:02 PM
saintz's Avatar
GL450
This car has fuses all over. My COMAND went out. I checked all three fuse boxes. I finally found the COMAND unit itself has a fuse on the back.
Old Jul 18, 2009 | 01:02 PM
LeeRod80's Avatar
99 E55 AMG
I'm all set now!! My boy Johnny hooked me up!!
It was nice to finally meet you in person bro!! Your E55 is nasty!!
Old Jul 18, 2009 | 10:37 PM
MR888's Avatar
E55
Nice tails are those 00 + stocks or aftermarkets? about time you came out of the 1996 stance
Old Jul 18, 2009 | 11:26 PM
armaniE55's Avatar
2012 CLS63 AMG
Talking
hahaha yup that's what I said! 00 + Jap Version they actually look good in person. Had to bust out the Soldering Gun to make it work
I drove his car.... She runs hella Strong for a 99 Very imprssive
Old Jul 21, 2009 | 03:03 PM
nelson09's Avatar
1999 E320
...same thing happend to me. Remember - you have a PREfacelift Eclass, the new tails I'm assuming are 00-02. I too wasn't aware of the 3rd fuse box when you open the door, but what you need to know is 96-99 tails use a different socket for the brake lights, I too blew a fuse and it was one there in the **** pit fuse box, but instead of jiggling the wrong socket so it fits just right, just go to the dealer and get two (white) sockets for the 00-02 tails. Happy Trails.
Old Jul 22, 2009 | 04:37 PM
armaniE55's Avatar
2012 CLS63 AMG
Cool
good info.. see I told you leerod you could buy the sockets.. oh well my soldering is just as good lol
Old Jul 22, 2009 | 04:59 PM
nelson09's Avatar
1999 E320
Sorry Admin - wasn't trying to use profanity there
OOPS!!! I was using that word in like airplane contex, any how I see how some may view that as vulgarity - wasn't intentional, I swear...You soldiered them - woah, the sockets are only like $7 each, but anyhow - problem solved I take it. Happy Trails.
Old Jul 22, 2009 | 05:36 PM
LeeRod80's Avatar
99 E55 AMG
Thanks, will do! Johnny, the right socket is loose again, bumps. I'll get the white sockets tomorrow.
Old Jul 22, 2009 | 05:46 PM
nelson09's Avatar
1999 E320
Cool, glad I was of some help - I drove around for a week or so like that..... LAMP DEFECTIVE = FUSTERATION. The parts guy at the dealer will know what what you need (they may be listed as white or "natural" but they are break sockets for 00-02 W210) GOOD MOD/mandatory for pre-facelift W210s (IMO of course) lol
Old Jul 22, 2009 | 06:40 PM
armaniE55's Avatar
2012 CLS63 AMG
Cool
sorry Leerod ...... I tried buddy
Old Jul 23, 2009 | 01:30 PM
LeeRod80's Avatar
99 E55 AMG
It's cool man, I appreciated it Johnny! These roads suck. I'm getting the new sockets today.
Thanks again to everyone who helped!
