Jacking points - W210 E55
Old Oct 20, 2009 | 05:23 PM
ultgar's Avatar
I didn't see any jackplates or jackpads for the W210 chassis on the various vendors sites....is there a site that shows the recommended jackpoints? Need to change my wheels/tires....I'm using the pad under the car in line with the jack insert slot but I'm not sure this is correct.
SD
Old Oct 21, 2009 | 08:29 AM
Peter_02AMG's Avatar
07E63, 12E350, 08997TT, 16SiennaSE
SD
There should be 4 round rubber pads on each corner by where you have that air jack. You can't miss it unless your is missing
Old Oct 23, 2009 | 05:28 PM
saintz's Avatar
GL450
This is correct.
Very odd jack, though. Just make sure it isn't too wide/large, or it can put too much pressure on the side skirt.
Old Oct 26, 2009 | 08:39 PM
Lawrence1's Avatar
2011 G55 + others
i like your jack and yes you have it positioned where the jacking points are. maybe push it in more(towards the center/exhaust) so it wont grab the sideskirt as much.
Old Oct 27, 2009 | 12:14 AM
Red66GT's Avatar
2008 S63 AMG Designo Edition
Where did you get that jack? How high does it go?
Old Dec 20, 2009 | 03:01 PM
ultgar's Avatar
I brought this one in from Esco (I sell their jackstands) to evaluate. I like the small footprint but it really doesn't go high enough (max 11").
I normally use a lift or a DK13 jack (see below) but the Esco air jack was handy and is easier to position under the jacking point.
Old Dec 21, 2009 | 08:00 AM
How much are they run?.I need one of those, I can't get a regular jack under my cars.
Old Dec 23, 2009 | 08:31 AM
ultgar's Avatar
AC Hydraulics is no longer being brought to the US...the DK13HLQ is the best low profile jack I ever seen and many of us were fortunate to buy them between 2000-2008. They can be imported out of Canada ($750-900) or you can find some cheap Chinese copies online between $200-300.
This jack had a long reach under lowered cars....height stayed under 4" for 16" of reach. SD
Old Dec 23, 2009 | 08:55 AM
maxwerks's Avatar
06 CLS55 Renntech stage 5, 04 CL600 ( will miss ),02e55 , 11 R350
I love that jack too , too bad they are no longer available in the states. I just looked them up at a place called asedeals.com , apparently they used to import them ... seeing the specs of the jack, the DK13HLQ it is rated for 2900 lbs. is that OK for our cars? it seems a little low for me... what is a good safe weight rating to get for our cars? The place above seem to have a couple of alternative options for the DK13HLQ , by Omega and ranger .. after seeing this post I have always wanted to good jack.
Old May 2, 2013 | 10:59 AM
ecd921's Avatar
Clk350
just bought my clk350 and it's 500 miles overdue on oil change...where can i position jackstands to the front? thanks alot for help.
Old May 2, 2013 | 11:42 AM
Red66GT's Avatar
Do yourself a favor and buy an oil extractor and do it from topside. It siphons the oil out through the dipstick hole. That way you don't have to get under the car and mess with taking the lower engine cover off. I bought mine from Summit Racing for $60 and I've already used it about 10 times (between my 210 and my boat). Worth every penny.
Old May 2, 2013 | 11:50 AM
ecd921's Avatar
Clk350
Thanx for the info Red66GT.
