W210 Door rust
Old Aug 29, 2011 | 01:04 AM
MB2001e55's Avatar
2001 e55 (Sold). 2006 E55 Flint Grey, 2003 330 CIC
W210 Door rust
I'm a newby to MB and my 2001 E55. Just purchasednmy E55 which is basically an immaculate car with only 50k miles. Absolutely love the car but found disappointing thing being rust. Doubt many have looked but under the door seal of the front passenger door, was surprised to find rust. Also beginning to see early signs on the right rear door as well next to the rubber seal. Rest of the car is perfect so made me begin searching online for design flaws. Also searched the VMI and found a line item called 2005 door preserve. Here is the link. http://www.mbca.org/forum/mb-recall-door-seals-w210s
Turns out that this was done on my car at 33k.
Here's the campaign memo.
http://www.mbca.org/sites/default/fi...10%20seals.pdf
Will post photos later after I figure out how to do that on my IPad.
Would love to hear what you experts know about this as well as any positive or negative experiences with the dealerships? Any suggestions on how best and cheapest to get this fixed?
Old Sep 16, 2011 | 10:30 PM
ESTJ's Avatar
2001 E55 AMG - 2001 E320 - 1990 300CE
Door Rust
I had the same problem. Removed the rubber seals, used wire wheel on a drill to remove most of the rust, applied naval jelly, cleaned and painted with black rustoleum enamel. No more problems.
This car is noted for rust in certain locations. Remove your front grill, you will probably find rust behind it as well, same fix as above.
Will send pics if you want.
