Is there a way to shift out of park if the
Old Aug 29, 2011 | 01:06 PM
trinitony's Avatar
E55 C43 993C2S
brake switch is totally dead? Wife just had to leave car at shopping center, and I won't be able to pick up replacement part until later this evening.
Thanks.
Old Aug 29, 2011 | 01:37 PM
KJI3jflarryfe93's Avatar
Thanks.
your lights should be dead, but not being able to drive the car is strange, this didn't happen to my c43 when the BLS died.
Old Aug 29, 2011 | 01:49 PM
trinitony's Avatar
E55 C43 993C2S
apparently once it's totally dead, the sensors go out of whack and it won't let you shift out of park. I'll be with the car in a couple hours and was trying to avoid having it towed......Maybe and ECU reset may do the trick...
Old Aug 29, 2011 | 06:16 PM
trinitony's Avatar
E55 C43 993C2S
Was able to move it after several tries. The trick was to turn the car on and let it idle for a bit. Got the part from the dealer and would change tomorrow.
Old Aug 31, 2011 | 03:52 PM
trinitony's Avatar
E55 C43 993C2S
Got it done last night. I must confess, I had my 13 yr old daughter remove and replace the part as I was tired and didn't want to fuss with getting to it. All is well now...
Old Sep 2, 2011 | 03:38 PM
Bellefonte's Avatar
2002 E55
I had this happen to me; brake switch failure didn't allow me to move out of park.
FYI: There is a transmission release button for situations like this. Near the shifter is a little cover that opens down, into the shift assembly area. You need to take a pen or something similar in size and press the button located under the cover. This will allow you to shift out of park. Caution should be exercised while driving as your brakes will be in limp mode (no ABS and such).
