E55 with Speedshift, Paddles, M Mode and other Mods
thanks for your input
i have the w203 c32/c55 discs and 4 piston calipers, should I use the master brake cylinder from w203 AMG cars for better braking?
greetings, Fabian
but as Fabian said; should to bend brake lines a bit, i will try that next week & let you know..
*assuming W220 N/A S55 & S55K sharing the same B & M/C, isn't..?
ZAYED,,
diagnose the car code: C1201 BAS release switch, replace it with another one, same issue, bought ESP hydraulic unit & B/MC, without luck...!,,
any clue with this Fabian..?
ZAYED,,
W202/W210 ... no matter if ME2.0 or ME2.8 based ... has HHT based ESP/BAS Control Units, the one from my S55 donator was allreadys DAS based and could be relearned, but i didnt get that to work either so i endet up with my w210 ME2.8 ESP/BAS Module. The BB from the W220 works without problems with that Unit.
Zayed, did you replaced the sensor with the one from your old BrakeBooster?
greetings, Fabian
As i switched vom ME2.0 ESP to ME2.8 ESP Control Unit I changed the Pressure Sensor in the ESP Module, the Sensor in the Brakebooster and the Gyrosensor. as far as i remember.
i had C1201 BAS release switch, this switch is a part of assembly booster that can't be changed, is that right..??
i think ESP module not accept new pressure that comes & go through the ESP hydraulic unit, not sure if that what happened to me..?!!?
ZAYED,,
I threw out the SL55 722.643 Transmission and installed a SL65 722.649 instead. Shifting is nicer in some kind i cant really explain
722.649 Electrohydraulic Unit
torqueconverter from the 649
torqueconverter from the 643
722.643 and 722.649
something missing...
also i installed new hoses...
And made some Soundchecks and 100-200km/h testdrives
Soundcheck
testdrives...
,when i taste the shifting of 649, can't go back to the stock, it's great..
very good hose fitment, like the way of alloy tube/silicone than plastic/rubber..
ZAYED,,
@VIPclk320
great!
Just take a look on it, the EGS51 has ... suprise ... EGS51 printed on it. If you have a stardiagnosis you can check as well, EGS51 is HHT, EGS52 ist DAS based interface. EGS51 mostly begins with 026 part number, EGS52 with 030.
Thanks for the offer but my paddles are also hard wired with a combination of a W210 and a W220 clock spring
greetings, Fabian
also it's 10lbs lighter than stock , and reduce some of rotation mass, it's idea to go with..
http://ultimatepd.com/index.php/upd-...000-stall.html
ZAYED,,
