W210 E55 Estate 2001
Old Sep 14, 2015 | 03:31 PM
Sachin Vara's Avatar
W210 E55 AMG Estate Prins LPG
Hi,
I would like to get rid of the hydraulic suspension and replace it with coilovers all around. Any suggestions where i can get it from? And how I would go about fitting them, because the steering fluid and suspension fluid is all linked together.
Cheers Sach
Old Dec 6, 2015 | 06:10 AM
madmobman's Avatar
1999 w210 E55T AMG
Originally Posted by Sachin Vara
Hi,
Cheers Sach
KW makes coilovers for the w210 e55 but if I'm right in assuming that the s210/w210 E55T is exactly identical then they should work. Can't give you any advice for the labour though.
Old Dec 9, 2015 | 02:57 AM
Ozimandius's Avatar
E55 AMG Estate, Lincoln MKX
I'd be interested in knowing about this possibility too. I also have a '01 S210, but without the adaptive damper feature, which I'm assuming is their way of naming the hydraulic suspension. But I believe the rear, self-leveling suspension is a factory, stock feature?
I found D2 Racing Coilovers but I don't know if they'll be compatible with the estate.
http://www.ebay.com/itm/281338189019?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Dec 9, 2015 | 08:25 AM
illest's Avatar
w210 AMG or S213
from what I have read you would need to install rear control arms from a sedan in order to fit coil overs and of course remove the self leveling plumbing.
