Brake Pad of Choice
While getting my E55 aligned yesterday I noticed I needed new front brake pads. Is it OK to replace the pads and not the rotors if the rotor thickness is in spec? What pad do you like? Mine are stock and very messy, also have more brake pedal travel than I like so I may bleed the brakes when I install the pads. Thanks for your input.
When i bought the car i didn't like the brake feel, so I installed SS brake lines from StopTech and replaced the fluid ---> less travel and feels snappier.
I'm using Meyle semi-metallic pads with RacingBrake rotors, dust is far less than stock and looks bright brownish. I believe there are better ceramic pads with even less/bright dust. Sadly i can't use ceramic pads with the rotors :( As for installing new pads on old rotors, if it's still within acceptable spec, I see no problem in it. |
+1,
Also, you have to measure Rotors thickness, if they less than (30mm), means new pads will be useless, prefer to change them at the same time, you can go with alternative Rotors during to the high cost of stock Rotors,(which i believe not it's worth it)..:confused: ZAYED,, |
Best stock feel pad IMHO is by Jurid. Light pedal effort and quiet.
I'm running Akebono ceramics right now, and they're my pad of choice
Originally Posted by benzokirk
(Post 6569233)
Originally Posted by ddb
(Post 6569478)
Me too. They probably don't work as efficiently as OE or OE equivalent pads, but they are close enough for me. They are soooooooo much cleaner than OE pads.
Thanks for the advice...I am leaning towards Jurid pads and OEM rotors along with new brake fluid...hopefully this will improve pedal feel and travel.
OE pads do dirty up the rim BUT I started using Armor All Wheel Protectant and it works really well. Keeps my rims very clean and when they do finally dust up a little, I use a spray bottle with water and rag. Takes 60 seconds for all four wheels.
I haven't had to replace my 55 pads in a while; however, earlier this year I replaced my SL65's OE pads with EBC Redstuff ceramics. Stopping power increased significantly. Fade and dust also reduced - dust is way down from OE pads.
I'll use them on the 55 when I need to replace... :y |
Originally Posted by pjdough
(Post 6570236)
Originally Posted by cm60k
(Post 6568007)
+1,
Depend of your choice Carl,
you can go with OEM drilled or slotted Rotors, on both, you have to re-drilled hole in the Rotors for small retaining screw, but it's not necessary, i used mine with out that retaining screw..:) ZAYED,, |
Thanks for all the replies. Has anyone used Hawk pads?
Originally Posted by Swiftmotoring
(Post 6581857)
I noticed you have or had an E550. Did you have the Hawk pads on that setup? If you did which ones the HP+ or the HP 5.0? I'm trying to decide for my 2014 E550. Thanks
Akebono & Zimmerman
Don't have anything to compare them to buti I love them and did I mention
....... NO brake dust I can compare them to OEM Most brake dust I've ever seen. They'd be dirty within one day. |
Akebono / Zimmerman
Originally Posted by GregScheller
(Post 7706509)
....... NO brake dust I can compare them to OEM Most brake dust I've ever seen. They'd be dirty within one day. Zero dust, pretty good feel for a long-life/Low dust pad, and rotors are coated for rust protection. IMO this setup is hard to beat for DD duty. |
Okebono & Zimmerman rotors
Very happy with them
Originally Posted by ProjectC55
(Post 6581095)
I have the red ebc pads waiting to go on:zoom:
Same here , it'll be the 3rd car with a full set . |
Zimmerman rotors OEM from FCP euro (Lifetime warranty) Hawk HPS Pads upfront Phantom Series Stainless lines and full MB fluid flush... Biggest brake upgrade i actually did was tighten my wheel bearings.
Brembo rotors and ceramic brembo pads in the back, less dust but squeal in reverse. BUT in my honest opinion the rotors that give the BEST bite are R1 Concept Slotted. Match those with some Hawk HPS pads and youre good to go. Ran then on my '05 cobalt SS back in the day, as well as just put a set on my buddies 450WHP bmw 435 and feel exactly the same...GREAT! |
